Replacement Antenna
Old Feb 25, 2004 | 02:45 PM
Screwchief's Avatar
Screwchief
Replacement Antenna
Has anybody replaced the antenna on their F150 with a shorter one? Mine keeps banging on my garage door at home and the parking garage at work. Are there any good replacement antennas out there and if so are they easy to install. Thanks for you input.
Old Feb 25, 2004 | 02:52 PM
Texan via Vermont's Avatar
Texan via Vermont
I have the same question. Sorry I don't have an answer. Picked mine up on Saturday and I cring every time it bends back and clangs when I enter/ exit the garage.
Old Feb 25, 2004 | 03:51 PM
Bdyzr1's Avatar
Bdyzr1
antenna
I have a billet antenna on my truck they make a 6 inch up to a 14 inch i have the nine looks real cool pricey though $
35.00
Old Feb 25, 2004 | 04:13 PM
Texan via Vermont
thanks. available on the web I suppose? billet.com or something like that?
Old Feb 25, 2004 | 04:19 PM
Bdyzr1's Avatar
Bdyzr1
any 4 wheel supply store should be able to get on for you, also check ebay
Old Feb 25, 2004 | 04:36 PM
Texan via Vermont
thanks! I'll look when I go get my tool box on Friday!
Old Feb 25, 2004 | 04:42 PM
stretch1's Avatar
stretch1
Go to http://www.antennaworld.com/ Replaced mine with a 16"
Works great. Just a matter of unscrewing the old one and screwing in the new one. Took about 2 minutes.
Old Feb 25, 2004 | 04:50 PM
fuzzola's Avatar
fuzzola
I had the problem and bought a euro-style one from www.antennax.com. Easy to install, looks and works great, and cheap.
Old Feb 26, 2004 | 08:43 AM
Screwchief's Avatar
Screwchief
How does the shorter antennas effect the radio reception. I looked at both the Billet & Euro Style on line. They both look sharp. I'm just wondering if one has better reception than the other. Thanks,
Dan
Old Feb 26, 2004 | 11:00 AM
stretch1's Avatar
stretch1
The reception on mine is awesome.
Old Feb 26, 2004 | 11:04 AM
luckild's Avatar
luckild
Had the garage problem and enough of it when it took out 2 bulbs, cut 1.5 inches off it and it worked just fine.Good luck.
Old Feb 26, 2004 | 12:04 PM
Tom B's Avatar
Tom B
15 Minute fix
On my '03 I just cut off about 4" then put the cut off section with the little ball on it in a vise and used a slap hammer type tool to pop it off. Get creative - it comes off fairly easy. Watch it though as it (the ball tip end) may fly across the garage floor. Then file down the OD of the remaining antenna top a little as it's tapered and may not fit initially. I used a speck of super glue to secure it. I spray painted the top a bit and it's been good for over a year. It had no effect on the reception at all.
