is it all right to gring valve reliefs a little bigger with a small air grinder I doen`t have to go deeper just bigger the valve justs rubbs the edge of the hole
there are flycutters available that fit into your valve guides and use a electric drill to cut valve reliefs , this may be done while the piston is in the block while a machine shop will need the pistons removed.
I use a flycutter with removable carbide cutters but I saw a article in Carcraft recently and they were using a specialized unit made for that purpose, If you can't find the article try the manley website or one of the piston mfgrs. No idea on cost --sorry
