FUEL VACUUM RELIEF VALVE
Yup, right; why is there air in the world?
Your both out to lunch.
Come on, the fuel systems are fuel injection under pressure; where are you guys getting anything about vacuum except at the fuel tank as part of the Evap test the PCM does.
It is illegal the have a glass fuel bowl in the fuel lines of high pressure injection system that can have pressures as high as 90 psi.
Justins68ford
07-23-2011 06:36 PM
