Replacing the steering column
Old Feb 24, 2004 | 04:00 PM
boogity24's Avatar
boogity24
Question Replacing the steering column
I plan on changing my steering column. I looked at the current one and realized how long it was. I plan on getting a shorter one and possibly a tilt (if the Lord willing). What would be the best setup to get? I plan on looking through the junkyard and was just wondering if I should be looking at a specific vehicle for a good tilt wheel.
Old Feb 26, 2004 | 06:10 PM
mk's Avatar
mk
The 78-9 F-series tilt wheel is a bolt in swap but you have to have p/s to make it work. Ford p/s boxes from 68-79 will bolt in also.
mike
Old Feb 26, 2004 | 06:27 PM
banjopicker66's Avatar
banjopicker66
If you have a manual steering gearbox or a Bendix power steering gearbox, then youhave a longer column.
If you have a Ford PS gearbox, then you have a shorter column.
Whay are you changing stering columns? I have one from a '72 if you are interested.
My e-mail is banjopicker66 at hotmail cot com.
Old Feb 27, 2004 | 02:56 PM
boogity24's Avatar
boogity24
well, my dad sees nice ones in the junkyard all the time, and when we switch out the column, we planned on putting in PS anyways, i was just wondering what the best truck is to rob the setup off of, PS box and all.
Old Feb 27, 2004 | 04:43 PM
banjopicker66
The swaps from manual to power steering and from drum to disc brakes are very popular on '65 and '66 F-100s. Search the '61 - '66 board for more details. Be careful though, because the steering for your truck is backwards compatible only to '65. Also, be advised that from '65 to '70 Ford used two types of PS boxes. The details were all there, so you should be able to figure it out easily.
From '65 to '79 it is mostly a bolt up, so you've got a real wide rang of choices.
Old Feb 27, 2004 | 09:46 PM
boogity24's Avatar
boogity24
I would just like to know why the column has to be so long. Is that just for the non PS so you could put strength into it¿
Old Feb 28, 2004 | 11:26 PM
Fomoko1's Avatar
Fomoko1
The difference is in the length of the steering gear box. There is no advantage in a longer column, except to make everthing fit properly.
sand1
Nov 4, 2021 07:21 AM
swoosh1958
Apr 25, 2017 05:13 PM
Cg willie Willie
Jan 18, 2017 09:14 PM
jplinville
WTB - Parts & other
Sep 2, 2016 04:02 PM
e william
Feb 26, 2004 10:31 AM
