anyone running kazaa, after you remove that program..mke sure that you open up your program files folder and delete anything associated with kazza, then run a spyware killer as mentioned above
Originally posted by jeffthompson That's a dirty trick what Kazaa puts onto a computer these days.
I downloaded and ran it and then removed it with spyware cause it was so bad.
Makes me wonder it the music recording industry is behind it.
Kazaa isn't the only one. Imesh, Bearshare, and Audiogalaxy are also ones to watch out for. Just use winmx and you won't have the problem, for now anyway. Also, if you don't like winmx look into eMule.
When your on the internet go to the tool bar at the top of your page, click on tools, click on internet options. you need to change your home page to yahoo or what ever you want and make that your default home page. You may have to do a search on your C-Drive for *Kazaa.* then delete anything associated with kaazaa.
yea, use kazaa lite, and make sure you use the ip blcoker with it too.....and store all your files out of the shared folders
i use spybot in conjunction with adaware and its works great...spybot even has a feature where u can lock your ie explorer so your homepage cant be changed and such
