1978 - 1996 Big Bronco
screwed over
Old Feb 25, 2004 | 11:07 PM
justshootme84's Avatar
justshootme84
I tore down a 350 one time, and found some thin metal shims under the main bearings. They were cut out of Coors beer aluminum cans. Just the right thickness for a worn crankshaft!!!
I would pull the heads and see what you have or don't have inside there.
Old Feb 26, 2004 | 08:22 AM
drbonestou's Avatar
drbonestou
Sorry didnt mean to hijack the thread..
But you see what I mean...good story...just hard to believe...not sure what happened to piston...I would have assumed it was in bottom of pan...because the wristpin was still in rod
But that is why I look at everything ...
because "some" ppl will do anything to sell a unknowing person a pile of junk..
And justshootme84.....someone must have had a degree in jerry rigging...to come up with the shim idea...LOL
Old Feb 26, 2004 | 10:37 AM
btnbronc's Avatar
btnbronc
If you are lookin for a new motor, try roadrunner engine i got my long block from them with a 3 year 75,000 mile warranty for about 1000.00 bucks you can contact them in Phoenix @ 1800-873-1818 or Salt Lake City @ (801) 972-3373 or El Paso @ (915) 533-6227 or Tucson @ (520) 792-1830 or Las Vegas @
(702) 732-1067. The nice part about it is they deliver!
Old Feb 29, 2004 | 06:53 AM
blrman1962's Avatar
blrman1962
I would check the valve train first much cheaper to do a valve job
Old Mar 12, 2004 | 08:39 AM
tom2131968's Avatar
tom2131968
Just get a new one
You won't regret getting a new engine. I bought mine from a canadian company called advance, not the same as the US auto parts firm, for 1400. It's a short block and came with a 3 year warranty. An engine swap, if done with the exact type as the original, probably on average takes little more time than doing a valve job and leaves you MUCH less to worry about in the long run.
