1978 - 1996 Big Bronco
Tranmission Problem
Old Feb 24, 2004 | 08:06 AM
mike88's Avatar
mike88
Tranmission Problem
My son took it to the snow this weekend and after he put it in 4WD, and took it out, it seemed to stay in 4wd? Since I wasn't there I don't have all the specifics, but it seems to run fine in D or L, but in OD it sounds like it is still engaged and won't go over 35. Also, Reverse doesn't work at all, thinks it's in N. Thoughts?
Thanks. Mike '88 302 - AOD
Old Feb 24, 2004 | 09:21 AM
jimandmandy's Avatar
jimandmandy
Push button or lever transfer case? If push putton, are the lights blinking?
Jim
Old Feb 24, 2004 | 09:40 AM
mike88's Avatar
mike88
Lights
It has the button. The light goes out. Both the 4wd and low go on and off ok.
Old Feb 24, 2004 | 09:54 AM
BillyBob69's Avatar
BillyBob69
Sounds like the hubs and /or the t-case hasn't disengagde. I know you said it wont go in reverse, but to disengage the hubs, (If auto), you need to back up about 10 ft. As for the transfer case..there is a small motor on it the engages your transfer case in and out when you hit the button. That is a known problem area. Some ppl have just removed it, cleaned and re-installed then all is good again. Other have had to replace it. I think the replacement costs about $70. As for it thinking its in neutral for reverse....have you tried moving the shifter a little further up to get it to engage? Have you looked underneath? Ummm maybe got up on something under the snow and whacked the tranny or transfer case out of the right position.
Old Feb 24, 2004 | 01:38 PM
The Tree's Avatar
The Tree
Well your son could have messed up the linkage try to keep messing with the shifter until it pops into all the gears. Check the tranny fluid.
Alabama Mike
29
Mar 3, 2013 05:26 PM
teederj2002
Feb 7, 2004 11:03 PM
eric88gt
Dec 30, 2003 03:50 PM
marragtop
Dec 5, 2002 06:13 PM
