Sponsored by: Kumho
more lift!
Old Feb 24, 2004 | 12:21 AM
threefiftyone's Avatar
threefiftyone
more lift!
I'd like to squeeze a couple more inches out of my now lifted '92 Bronco. I've got a Rancho susp lift, 3" or 4" I'm not sure. I know they offered either a 3" or 4", but I've no way to tell since I bought it with the lift already on. (unless someone out there can tell me) Why they even offered a 3" or 4" is still a mystery to me, there's not much difference! Anyhow, I was curious if any one has had any luck using coil spacers up front. And maybe some 2" add-a-leafs out back. My rear drive shaft has been extended, but would I need to go further with more rear lift? I'd sure like to stay away from those nasty body lifts. (ya know, because I actually 'wheel my rig)
Old Feb 24, 2004 | 11:36 AM
notchstang92's Avatar
notchstang92
I used the add a leafs in my stock springs when I lifted my 94 4x4 and it worked out ok. If I had it to do over again I would have gotten the full replacement leaf springs. The add a leafs aren't bad and better than blocks if you offroad, but my truck w/ 67000 miles on it had rotted out a leaf already and the others looked less than desireable.
