Sponsored by: Innova
Sony XRC9100 Help
Old Feb 23, 2004 | 10:13 PM
Khrystn's Avatar
Khrystn
Sony XRC9100 Help
I have a Sony XRC9100 and a massive crossover - I just installed four 4-channel Rockford Fosgate Amps to complete the system, but somewhere I've messed up the wiring. I know I have the crossover and amps wired up right, but I lost the wiring diagram to the Sony stereo, so I'm working on memory on that one. If you have am XRC9100, is there any chance you'd be willing to scan a copy of the wiring diagram and email it to me? I'd really appreciate any help.
Thanks, guys.
Kristin
Old Feb 24, 2004 | 07:21 PM
prcrboy's Avatar
prcrboy
Sony uses two different connectors depending on model. (I believe, I'm no expert, but this is straight from Sonys website.)
Pin Number Wire Color Function
1 Not Used
2 Black Ground
3 Grey Right Positive
4 Grey/Black Right Negative
5 Blue/White Amplifier Remote
6 Red 12 Volt Switched
7 Yellow 12 Volt Constant
8 White Left Positive
9 White/Black Left Negative
1 White Left Front Positive
2 Green Left Rear Positive
3 Violet Right Rear Positive
4 Grey Right Front Positive
6 Blue Antenna Remote
7 Red Accessory 12 Volts
8 Black Ground
9 White/Black Left Front Negative
10 Green/Black Left Rear Negative
11 Violet/Black Right Rear Negative
12 Grey/Black Right Front Negative
13 Sky Blue Telephone Mute
14 Orange/White Illumination
15 Not Used
16 Yellow Constant 12 Volts
Old Feb 25, 2004 | 01:39 AM
Khrystn's Avatar
Khrystn
Thanks, prcr - The second one sounds like the right connector. I'll have to take a look tomorrow.
bigdaddyII
2009 - 2014 F150
Apr 18, 2016 01:57 PM
pilot10
Aug 10, 2014 01:34 PM
Texas Bob
Jan 8, 2014 07:37 PM
WGFA
Nov 25, 2012 09:37 AM
jbateman73
Aug 2, 2010 12:56 AM
