I have an 88 fullsize bronco with a 302 does anyone know what if any companies makes an exhaust system that will change the stock exhaust to dual exhaust coming out the back
I ordered a cat back exhaust with split rear exhaust. I ordered it for an extended cab pickup and cut the pipes as needed. the location of the muffler is why I ordered for the extended cab. pipes exit on the outside of the frame rails. it's been a couple of years but I believe it's a flow master system.
I had my favorite pipe bender do a custom single in dual out system. Replaced second cat with a 3" in 3" out racing cat, followed by a Flowmaster 40 series 3" in dual 2.5" out. Dual pipes exiting behind passenger wheel. Looks and sounds awesome. Pics in gallery, more/better pics on website.
the problem with ohrtman19's system is it doesnt create any back pressure. that exhaust setup will kill your low end power. and unless your running a screamer of an engine its worthless .
doesnt matter what motor your running. your exhaust is strait threw. if you had a single 3 inch with at least a muffler you would notice night and day difference to what you are running now.
