throttle body?
Old Feb 23, 2004 | 03:52 PM
modru2004's Avatar
modru2004
throttle body?
anyone know where the throttle body is at on the truck in my sig and what it looks like. im gonna clean it.
Old Feb 23, 2004 | 03:59 PM
FordMan94's Avatar
FordMan94
its mounted to the front of your upper intake manifold. only takes 4 bolts to unbolt it and have to remove the throttle cable and possibly a couple rubber hoses. why you cleaning it? looks?
Old Feb 23, 2004 | 04:34 PM
modru2004's Avatar
modru2004
idles surging and in another thread someone mentioned that cleaning the throttle body might work.
Old Feb 23, 2004 | 06:18 PM
MustangGT221's Avatar
MustangGT221
Don't clean the coating off the outside. Just use some carb cleaner on the inside...
The easiest way to find it..is it's what the plastic air intake tubes are mounted to under that black cover ontop of the engine.
Old Feb 23, 2004 | 08:12 PM
FordMan94's Avatar
FordMan94
mustanggt221-
whats the best way to clean the outside of the body? i'm rebuilding a 302 and the throttle body is of course pitted. just old looking aluminum. is there a good way to make the outside of it look like new again? any ideas?
Old Feb 23, 2004 | 08:36 PM
aikigod's Avatar
aikigod
Careful on using carb cleaner. Some of the throttle bodies (like mine) have a special coating on the inside that the carb cleaner strips off (you'll see a sticker on the throttle body saying "do not clean" or something like that - don't worry about it though). I'd recomend getting a throttle body cleaner - it's supposedly safe for the coatings. As Mustang said, you just take off the intake tubes and spray the inside as per the directions.
Old Feb 23, 2004 | 08:37 PM
brown 4x4's Avatar
brown 4x4
The "special coating" is on the inside. Carb cleaner will take it off. You can use special throttle body cleaner that won't remove it if you want. But since that coating didn't prevent the TB from getting dirty, IMO it's probably not a big deal if it was removed as long as you keep it clean in the future.
Dang Gregg, we posted at the same time and they say pretty much the same thing.
Old Feb 23, 2004 | 09:00 PM
modru2004's Avatar
modru2004
i have a can of johnsens carb cleaner. is it safe to spray the inside, it won't do any harm will it? i know you said it might strip the coating but does that coating do much good?
Old Feb 23, 2004 | 11:33 PM
aikigod's Avatar
aikigod
hehe brown, I beat you by a minute
Old Feb 24, 2004 | 12:35 PM
fordtruckfan90's Avatar
fordtruckfan90
Be careful when you clean the Throttle Body, and replace the gasket before you put it back on, dont forget that step, when the throttle body is back on, but not completely, start the engine, and spray air intake cleaner while it is running, it will bog down, but it will clean it.
mcd432
2004 - 2008 F150
Oct 24, 2012 08:14 AM
OGNOM
Modular V10 (6.8l)
Mar 14, 2003 03:53 PM
Wilber15
May 22, 2002 05:12 AM
paulg
May 25, 2001 05:19 PM
