Adding horn button....
Old Feb 23, 2004 | 02:47 PM
txwing's Avatar
txwing
I bought a button at wally-world that's supposed to be connected to negative/ground and to "horn wire" but I can't find the wire that makes the truck horn work.
What color is the horn wire under the dashboard? (I don't want to take off the steering wheel.)
Thanks in advanced....
71-f100
Old Feb 23, 2004 | 03:07 PM
fordranger68's Avatar
fordranger68
I'm pretty sure the wire is blue and orange. that's what it was on my 68 ford when i was messing with the turn signal switch this weekend. hope that helps!!
Chris Baer
Old Feb 23, 2004 | 03:21 PM
txwing's Avatar
txwing
Yes. The blue & orange wire from the horn is that color, but when I try to find it under the dash, I can't find it there?
Also, I connected the the button to the blue/orange cable, and to the negative battery terminal and nothing happened.
Am I connecting it wrong?
Old Feb 23, 2004 | 06:20 PM
8NRay's Avatar
8NRay
The horn is activated by the horn relay. It is located on the radiator core suport near the voltage regulator. When you press the horn button (rim) on the steering wheel, it connects the horn wire to ground causing the relay to activate, and in turn, activates the horn.
Old Feb 23, 2004 | 06:25 PM
Comegetsome's Avatar
Comegetsome
I'm experiencing some difficulties with the horn system myself, on my '67 F100. The PO had installed a horn button on the dash and wired it from the fuse box, to the switch and directly to the horns instead of replacing the worn rag joint which caused the original horn button not to work. Now I can't find the original wiring to connect it back properly.
The horn relay? I have what appears to be a relay mounted on the passenger inner fender, a three prong triangular shaped relay which I am assuming is the horn relay, but it has been disconnected and the harness is just dangling beside it. Can anyone confirm my suspicions on this?
Old Feb 24, 2004 | 10:38 AM
MuchToMyDelight's Avatar
MuchToMyDelight
yup- thats it. It should have a large yellow wire going to it from the starter solenoid so it has power at all times. The blue/orange wire should be in the same harness as the turn signal stuff coming out of the steering column.
Old Feb 24, 2004 | 11:59 AM
Freightrain's Avatar
Freightrain
The relay has THREE wires. The large yellow is the main power. The blue/yellow tracer is the ground wire that runs to column. The other wire runs to horns themselves.
If you ground the blue wire anywhere the relay with function and activate the horn.
Look at the wiring running up the column for turn signals, it will be there. Connect off it there and hook to button. Hook other side of button to a ground somewhere(like the screws used to hold button). If you get NO click from relay, then the relay is possibly dead or you have no power to it.
Use a volt meter to check the connections to see what is not working. Ground the blue wire under column and then check for continuity at relay. It should read between terminal and ground. Then check for 12volts. If both good, then it's the relay.
Larry
P38fighter
May 24, 2014 07:28 AM
Duckmang
Jul 28, 2013 11:40 PM
F350moneypit
19
Feb 4, 2013 01:46 AM
Freightrain
Jul 9, 2012 12:47 PM
sleddog60
May 18, 2009 09:29 PM
