oil
Old Feb 23, 2004 | 02:20 PM
ford390gashog's Avatar
ford390gashog
oil
the owners manual of my 2003 4x2 expedition says to add six quarts of oil i did and it overfilled it a lot could you tell me how much you guys put in the engine is a 5.4
Old Feb 23, 2004 | 03:13 PM
AceJams's Avatar
AceJams
My 97 with a 5.4 takes 6.5 quarts to fill it to just a hair under MAX on the dipstick...
Old Feb 23, 2004 | 03:19 PM
daveplot's Avatar
daveplot
I put 6 quarts in my 03 and it didn't overflow.
You did drain the oil and removed the filter and let it drain, right?
Old Feb 23, 2004 | 03:36 PM
tsdrallyer's Avatar
tsdrallyer
When I change oil, I always change the filter too. Before mounting the filter, I fill it with new oil so there is no time delay for oil delivery when cranking to check for leaks. Using this system, I find that a total of 6 quarts brings the oil up to the full line on the dipstick.
I suggest you should always drain the oil while hot, so all oil comes out and only a trace remains in passageways, valve covers, etc. If very cold in winter, up to a quart could remain inside, stuck to interior surfces. Remove oil filter first, so any suction is relieved and oil can drain back to pan. Make sure none is dripping from pan drain opening, before replugging.
Old Feb 23, 2004 | 03:42 PM
Monsta's Avatar
Monsta
Sit. Stay.
Old Feb 23, 2004 | 07:54 PM
buzzard's Avatar
buzzard
The guys at the oil change places are always charging me for an extra quart, so I presume mine takes 6.
Old Feb 23, 2004 | 08:35 PM
FarmLaw's Avatar
FarmLaw
--Jealous of TSDRallyer's remote mounted oil filter--
To pre-fill my oil filter without spilling, I'd have to take the forklift and dump the truck over on the driver's door.
Old Feb 24, 2004 | 07:10 AM
hceptj's Avatar
hceptj
It takes me 6.5 qts to get to the full mark also. Not really sure how it could have been over-filled with only 6 qts????
lol@farmlaw
Old Feb 25, 2004 | 01:19 AM
ford390gashog
thats what i don't under stand
Old Feb 25, 2004 | 01:32 PM
ford390gashog
what type of oil should i put in
Old Feb 26, 2004 | 04:46 AM
msm718's Avatar
msm718
For the 2003 I believe 5W20 oil. I use Synthetic Mobil 1 5W30 since I have a older model than you.
Old Feb 26, 2004 | 07:44 AM
02PSD4ME's Avatar
02PSD4ME
I put in 6qts of the Motorcraft 5w20 in it and it is FULL.
Old Feb 26, 2004 | 09:59 PM
Matt03Expy's Avatar
Matt03Expy
Remove oil filter first, so any suction is relieved and oil can drain back to pan.-tsdrallyer
A good tip. But I disagree about draining the oil while the the oil is hot. If you work on the truck when cold, you don't burn yourself and there has been plenty of time for all the oil to drain to the pan. I have never seen more oil come out hot versus cold. When changing tranny fluid on my 89 Dodge van , they said wait two days to make sure the torque converter was completely drained before changing fluid.
