Sponsored by: Real Truck
Tires need help deciding
Old Feb 23, 2004 | 10:00 AM
cmcaninch's Avatar
cmcaninch
Question Tires need help deciding
I want to get new tires but at the price of them I would hate to have the same problem i have now
I bought the truck and it has cooper 265x75x16 on it they ride
like a flinstone mobile someone mounted 4 rocks on the rims and called them tires you could spit on the road and I could feel it
and concidering I live in ohio our roads are anything but flat
I would like a little bigger tire but I dont know what I can get away with I was concidering either Michlins or BFGs but at aprox $160 ea I would hate screw this up
Thanks for the input in advance
Old Feb 23, 2004 | 10:14 AM
ktm520mxc's Avatar
ktm520mxc
I have a 2000 F350 V10 and I ran the BFG 285/75-16's and they were a good tire, a little noisey but not too bad. I just put a set of the Bridgestone A/T Duellers Revo's on it and thet are Awesome. They are quite, smooth riding, and work great in all types of terrain. Another p[lus is Bridgestone guarantees them for 50,000 miles. I'm running the same size as the BFG's I had.
The cost is about the same as the BFG's.
Old Feb 23, 2004 | 11:02 AM
CAT_man_963's Avatar
CAT_man_963
If you want a smooth ride go with the 285/75 and an all terrain to a street tread. Another little thing is you don't have to run the tires at that max sidewall pressure. That infl. pressure is for the max load rating of the tire - I run around with about 20 psi less in the rear tires than the fronts and usually about 10 less than max sidwall in the fronts - gotta support that heavy diesel!!
Good Luck!
Old Feb 23, 2004 | 03:07 PM
mikesZ06's Avatar
mikesZ06
I recommend going with the Michelin LTX MS. They wear like iron, hold their balance and ride great.
Old Feb 23, 2004 | 04:04 PM
obxtuna's Avatar
obxtuna
Talking
I second the Michelin LTX M/S suggestion.
I put on the 285 version of this tire with some Bilstein shocks and the ride is great. I spend alot of miles on the interstate and could not be happier with the upgrade....
Old Feb 23, 2004 | 05:01 PM
boxcar1974's Avatar
boxcar1974
I just put bridgestone dueler A/T revo's on my truck.....They are awesome....ride quiet....good tread.....and excellent wet road traction...and best of all....I baught them brand spakin' new on ebay for $120 a tire......retail around here were $165 a tire.
Old Feb 23, 2004 | 06:07 PM
Outpost22's Avatar
Outpost22
Michelin LTX M/S ride very nice, wear well, are very quiet and work well in snow. They are also "E" rated for 3415 lbs in a 265 10 ply.
Old Feb 23, 2004 | 06:59 PM
spartan's Avatar
spartan
I vote for the Bridgestone Dueler AT Revo's. We have them on a Landcruiser and they are supreme. They replaced BFG AT's and I will say they are far better riding, quieter and handle better. As for wear and tear - we'll know in about four years or so.
I've consistently gotten 50,000 miles per set of BFG AT's and the 35's on my X look like they could go 55,000 easy. I'm tired of them though and looking at other options including going with 285 AT Revo's - biggest size made, Yokohama Geolanders or Nitto AT's in 295 size. I'm tire of the road noise from the 12.5" tread.
Lowered the truck. going to smaller tires, can you tell I'm getting old?
Old Feb 24, 2004 | 07:54 PM
cmcaninch's Avatar
cmcaninch
has anybody had any luck with the dunlop radial rover at
Old Feb 24, 2004 | 08:28 PM
Panzerbrumbar's Avatar
Panzerbrumbar
I have about 20,000 miles on my Yokohoma Geolandars I love them. Nice looking, quiet, good traction and reasonably priced. I will buy another set if they keep performing like they do.
Old Feb 25, 2004 | 09:56 AM
NoMo's Avatar
NoMo
Before spending $$ on new tires (I like BFG ATs), have you checked the air pressure in your current ones? No need to run 80 psi if you're running with no load.
Old Feb 25, 2004 | 03:52 PM
Redlined's Avatar
Redlined
Ive got a 01 f250 v10 - any one know if i can fit a set of 315-75-16 mtx radials on with out a lift kit?
Red
Old Feb 25, 2004 | 04:36 PM
spartan's Avatar
spartan
Generally speaking you need a three inch lift in the front to run 315's - safer to go 4 inches.
Old Feb 25, 2004 | 04:49 PM
bubbasz1's Avatar
bubbasz1
I run the Michelin LTX M/S, on my E250, and my F350, best tires I ever bought.
Old Feb 25, 2004 | 04:56 PM
Bob Ayers's Avatar
Bob Ayers
My vote is for Michelin LTX M/S ...I have 50K miles on a set, and they look like they will run another 50K!!!! Very smooth!!!!
