Timing Set ?
Old Feb 22, 2004 | 06:23 PM
mgraveman's Avatar
mgraveman
I just checked part numbers at the parts store. The timing chain is the same 70-82. Is there a step key to get that 4 degrees?
Old Feb 22, 2004 | 08:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
You need a performance timing chain that does not have the 4 degree retard built in.
Old Feb 22, 2004 | 10:24 PM
mbehrends's Avatar
mbehrends
what does the 400 respond best to? The O degrees or 4 degrees advanced? I'm looking for low to mid range power and always better mileage.
Old Feb 22, 2004 | 11:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
The stock cam is best at straight up or 0.
Aftermarket cams are normally designed for 0 also but sometimes they change them slightly. I have always felt that if the cam is not set at 0 then it was ground wrong for the application.
dwil
Arizona Chapter
Apr 7, 2014 09:18 AM
ford390gashog
Apr 5, 2006 03:48 PM
tonpartain
Mar 22, 2006 08:45 AM
djtuna
Nov 17, 2005 12:32 AM
petem
Feb 25, 2002 08:09 PM
