Bronco II Ford Bronco II
2.9 Performance camm
Old Feb 22, 2004 | 06:22 PM
FXDXFilo's Avatar
FXDXFilo
Unhappy 2.9 Performance camm
I'm rebuilding an '88 BII 2.9 to install in my '89 BII. I've got better flowing heads with larger exhaust valves. A polished and matched intake system, a higher compression for the combustion chamber by milling and using 2.8 flat top pistons, and a true tuned exhaust. Further plans include cold air box and chip. The only problem I'm having is the stock cam. Not enough torque in low and mid range. I'm asking for any help out there in finding a better of the shelf cam from an aftermarket company or stock cam from a different 2.9 use (IE. a Mekur, Scorpio or other vehicle). Can anyone help?
Filo
Old Feb 28, 2004 | 06:11 AM
wolffpax's Avatar
wolffpax
Have you checked out camcraftcams.com yet?
Old Feb 28, 2004 | 09:48 PM
FXDXFilo's Avatar
FXDXFilo
Smile Thank you!
Thank you for the information! This maybe the best answer to my problem. Thank you very much sir!
Old Feb 29, 2004 | 06:54 PM
wolffpax's Avatar
wolffpax
Not a prob. They offer a lot more than the cams. If you check them out they offer a set of really nice roller rockers. Something else on my wish list, that list just keeps gettin longer and longer.
