If your truck is lifted and has at least 35inch tires I would recomend the Fox stabilizer. It is a little pricey but definately worth it in my opinion. When I went from a 4inch lift with 35's to a 8inch lift with 38's I had to leave the old Rancho stabilizer on the truck while the Fox stabilizer was shipped, so I got to drive the truck with both the difference was night and day. Plus they look really cool.
I just replaced mine on my 2001 F350 4x4,stock suspension.
Napa-----Monroe part # SC2961 $ 32.00.
I tried to locate a Bilstein unit,but they don't offer one is what I was told by several different shock vendors.
Well, if your running stock tires, I would just replace the stock stabilizer, I think most shock manufactures, i.e. Skyjacker, monroe, etc make them to fit the stock mounts.
No need to spend a ton of money on a custom after market unless you run bigger wider tires.
Originally posted by Yeti Well, if your running stock tires, I would just replace the stock stabilizer, I think most shock manufactures, i.e. Skyjacker, monroe, etc make them to fit the stock mounts.
Im only running 2 tire sizes larger than stock so probably a stock one will be ok.
