99 Powerstroke Induction Howl
Old 02-22-2004, 02:07 PM
allemay's Avatar
allemay
allemay is offline
I have a 1999 F350 with the Powerstroke. At 2100 rpms it makes a very loud howling like the secondaries opening on a Holley 4 barrel carburetor. It doesn't matter if it's under load at that rpm or just maintaining speed. It occurs in all gears and in park. I have a friend with an identical 2000 F350 that doesn't make any induction type of noise.
Anyone have any idea what's causing it? It can't be normal. It's intollerable at 2100 rpm which with my 4:10's is right about 63 mph.
Old 02-22-2004, 04:06 PM
CAT_man_963's Avatar
CAT_man_963
CAT_man_963 is offline
Do you have an aftermarket intake on it or any other mods, or is it all stock??
Old 02-23-2004, 12:55 PM
allemay's Avatar
allemay
allemay is offline
It is all stock. Even the stock air filter in the original housing.
Old 02-23-2004, 01:39 PM
96 stroker's Avatar
96 stroker
96 stroker is offline
Are you sure it is in the air induction. We just had a psd do the same thing (howl) it didn't happen until rpms were around 2200 a week later the turbo locked up tight. Not saying it is the same problem just giving you a personal experience with that noise.
Old 02-23-2004, 01:52 PM
allemay's Avatar
allemay
allemay is offline
I don't have any idea what it is, it just sounds like a bunch of air rushing in. The truck only has 51K so I hope the turbo doesn't go yet!
shultzaberger
11-04-2014 02:38 PM
raydav
29
08-21-2014 11:54 AM
wpcol
09-08-2001 06:34 PM
Quick Reply: 99 Powerstroke Induction Howl
