Spout connector
Old Feb 22, 2004 | 12:35 PM
Rockranger's Avatar
Rockranger
Spout connector
Hi All I got an 87 ranger with a 2.9 They say to disconnect the spout connector when setting the timing Where the heck is it located and what does it look like
Thanks a bunch
Old Feb 22, 2004 | 12:43 PM
lakahahahman's Avatar
lakahahahman
follow the wires back from the ignition module on the distributer on the passenger side of the engine and you will find just a single wire that has a little plug in it kinda t shaped that is your spout connector you cant miss it just hanging there
Old Feb 22, 2004 | 12:50 PM
hreed's Avatar
hreed
It's easy to break the plastic connector, so be careful taking it apart.
Old Feb 22, 2004 | 02:11 PM
Rockranger's Avatar
Rockranger
I"m not sure
Thanks for the speedy reply Alli found so far was two yellow wires by the rear of the intake there is a plug with a little thing plugged into it is this it I can send you a picture
Old Feb 22, 2004 | 02:16 PM
Donald Rohret's Avatar
Donald Rohret
Question
"Spout" is an abbreviation for "Spark Output". I had the same problem when I read a code referring to "Spout". It's the single insulated coil wire.
Old Feb 22, 2004 | 02:47 PM
Rockranger's Avatar
Rockranger
I must be stupid cause I looked and can"t find it yet
Old Feb 22, 2004 | 06:23 PM
hreed's Avatar
hreed
Get the engine timed as best you can without disconnecting any plugs. Then, while the engine is running, unplug the one with two wires. If the engine idle changes (should drop) thats the plug.
Old Feb 22, 2004 | 09:15 PM
Rockranger's Avatar
Rockranger
Thumbs up Got it
Thank You Hreed Everyone said that the spout connector has one wire mine has two yellow wires going into a black connector with a t shaped thing that plugs into it.I unplugged it as the truck was runnin and the motor almost quit.Gotta be it
thanks a bunch
RyanJake
Jun 29, 2004 06:18 AM
fishingboy
Nov 1, 2002 07:54 AM
Franklin2
Aug 6, 2002 12:01 AM
hokeyson
May 21, 2001 03:02 PM
