themastat
Old Feb 22, 2004 | 10:31 AM
dbwood55's Avatar
dbwood55
themastat
i just installed a new thermastat in my 82 f-150 ford, 302. the temperature gauge is still reading 3/4 of the way to hot. the guy at the auto parts says it has an air bubble in the system. my question is how to bleed the air ouy of the system (if that is the problem)
Old Feb 22, 2004 | 01:33 PM
desperado_18_2000's Avatar
desperado_18_2000
When the truck is cool, take the radiator cap off...and start the truck and let it idle till the thermostat opens and the coolant level in the radiator drops.... once it does this....put the radiator cap back on and that should have allowed the air bubble out of the system.
Old Feb 22, 2004 | 04:01 PM
BLaCkSiLo's Avatar
BLaCkSiLo
generally, how long does it take for the thermostat to open?
Old Feb 22, 2004 | 04:53 PM
Franklin2's Avatar
Franklin2
Depends on how cold it is outside. Probably 15 minutes will do it. When it opens, the top radiator hose will get noticeably warm, and you will see coolant flow in the radiator.
Old Feb 22, 2004 | 08:44 PM
Canute's Avatar
Canute
Aftermarket parts stores sometimes sell higher temp thermostat's than oem. They should tell you this but you never know...
Old Feb 22, 2004 | 09:52 PM
fordeverpower's Avatar
fordeverpower
maybe a bad head gasket?
Old Feb 23, 2004 | 10:59 PM
Timken's Avatar
Timken
A bad head gasket (one that leaks into water system) will show bubbles in the rad. when running.
Old Feb 23, 2004 | 11:39 PM
Mil1ion's Avatar
Mil1ion
Except for under a load ,I'm pretty sure it gets hotter quicker at idle. Don't quote me though.
