1978 - 1996 Big Bronco
pinion bearing replacement
Old Feb 22, 2004 | 04:04 AM
blrman1962's Avatar
blrman1962
Question pinion bearing replacement
I need to replace my pinion bearings in a 8.8 rear is there any way to do this with out the pinion depth tool or any good web sites for help or where can I get one cheap please let me know thanks
Old Feb 22, 2004 | 04:51 AM
RTM's Avatar
RTM
If the pinion bearing is bad then the ring gear will have developed a wear pattern to the bad bearing meaning a new bearing will cause the gears to howl or wine when you drive. It may be best to replace/rebuild the 8.8.
