starting problems
Old Feb 22, 2004 | 01:23 AM
gatoroakes's Avatar
gatoroakes
starting problems
i have a v-6 '91 F-150 thats an automatic
my problem is that i can't start it from park anymore, the only way is to jimmy the gear indicator to a specific spot inbetween park and reverse. basically i feel the gear lock in but for some reason the truck doesn't recognize that its in that gear.
is this a lost cause, some thing i'd need to take into a shop for repairs, or something that i can expect to repair myself?
thanks for the help.
Old Feb 22, 2004 | 01:43 AM
PKRWUD's Avatar
PKRWUD
There were no V6 F150's in 1991, but the problem you are describing sounds like a bad neutral safety switch.
Old Feb 24, 2004 | 12:36 AM
gatoroakes's Avatar
gatoroakes
ok, so exactly whats invovled with checking that switch out
i'm pretty much a total novice at working on trucks, so excuse my ignorance
Old Feb 24, 2004 | 03:08 AM
PKRWUD's Avatar
PKRWUD
To check it out, get under the truck and unplug the connector from the switch (drivers side of tranny). Connect the leads from a multimeter to the two red/blue wires going to the switch, and set the meter to ohms. Have someone shift through the gears, one at a time, while you observe the readings on the meter. In Park and Neutral, it should read 5 ohms or less. In all other gears, it should read greater than 100k ohms. If it doesn't, it needs to be replaced.
Old Feb 24, 2004 | 12:31 PM
fordtruckfan90's Avatar
fordtruckfan90
PKRWUD, thanks, no f-150 ever came with a v-6, thats an insult in my mind...lol, it is an inline 6 very dependable motor over the v-6
Old Feb 24, 2004 | 03:30 PM
fordlover_696's Avatar
fordlover_696
I LIKE MY SMALL BLOCKS OR BIG BLOCKS BETTER THAN ANY I-6
Old Feb 24, 2004 | 03:35 PM
fordtruckfan90
most guys that end up replacing the I-6, regret doing it
Old Feb 24, 2004 | 07:12 PM
fordlover_696
NOPE I LOVE MY SMALL BLOCK AND I WOULDNT GO BACK TO THOSE GUT LESS IN LINE SIX'S
Old Feb 25, 2004 | 09:10 AM
jimandmandy's Avatar
jimandmandy
Ford DID sell a V-6 F-150 in Mexico in the early '90s. It was the 3.8 from the Mustang/Thunderbird. Cheaper, I guess.
Jim
Old Feb 25, 2004 | 11:35 AM
PKRWUD's Avatar
PKRWUD
Jim
¿Qué? ¿Realmente? Usted ha estado en tan la caloría demasiado larga. lol
Nunca oí eso antes. Nunca he encontrado cualquier Info en un V6 F150 hasta 1997. Muy interesante.
Cuidado de la toma,
~Chris
Old Feb 25, 2004 | 11:48 AM
fordtruckfan90
ay, esta bien, no quiero un v-6 esta a mi troca pero un treinta punta och tiene problemas con los headgaskets.
