Bronco II Ford Bronco II
Insturment Voltage Regulator
Old Feb 21, 2004 | 07:00 PM
broncoray's Avatar
broncoray
What is the Voltage to measure after this Regulator
Ray
Old Feb 22, 2004 | 12:11 AM
87 XLT's Avatar
87 XLT
5 volts. If none of your instruments are working check for a clean tight connection of the body to engine ground strap.
Old Feb 22, 2004 | 05:00 AM
broncoray's Avatar
broncoray
Ok, thanks.
I have to change a lamp that is brooken in the spedometer do I have to take the komplete instrument unit out?
Ray
Old Feb 22, 2004 | 12:46 PM
87 XLT's Avatar
87 XLT
Probably so, haynes manual will tell you how to do it
