Sponsored by: Real Truck
front end noise
Old Jan 14, 2002 | 01:52 PM
Magyver's Avatar
Magyver
front end noise
Hi new to the site but not to SD
wondering if anyone has had a front end sqeak (loud )in a 2000 SD
7.3, when going over a large bump. Especially when it is cold out, it is not noticeable when warm. Sounds like it is coming from the front springs but not sure. Checked all of the fittings in the front
end found nothing. Appreciated any help and am glad I found this
site lots of great info here
Old Jan 14, 2002 | 01:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
front end noise
[updated:LAST EDITED ON 14-Jan-02 AT 02:55 PM (EST)]yes, my 2000 Excursion makes the same noise. It is being checked out as we speak. If no one else does, I'll update you in tomorrow.
BTW, welcome to the site it's good to have ya!!
Old Jan 14, 2002 | 03:17 PM
powerstroker250's Avatar
powerstroker250
front end noise
My truck just started doing this on the left side. Alot of guys are finding that it is the sway bar link bushings and/or loose link bolts. That's what I am going to check first.
Monsta, keep us updated.
Les
Old Jan 14, 2002 | 04:47 PM
abendx's Avatar
abendx
front end noise
mine does it too..... it is momentary and i usually find bow ties and 11" chevy lift kit parts in my tire tread soon after the squeaking incident?
does anyone know why this might be happening?
Old Jan 14, 2002 | 05:37 PM
powerstroker250
front end noise
abendx,
Maybe you need a remote camera mounted on the front of that truck so you can see all those small ch*vys before you run over them, but then I guess you wouldn't be having any more fun. It would eliminate your squeaks though
Les
Old Jan 14, 2002 | 06:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
front end noise
Man, you crack me up!
Old Jan 14, 2002 | 06:24 PM
rsjohnsn's Avatar
rsjohnsn
front end noise
There is a TSB for this, the number is 13148 and the bulletin sequence number is 609. I'm not sure what the problem is or the fix but I sent off for more info. I will post as soon as I find out unless someone beats me to it.
Thanks
Scott
Old Jan 14, 2002 | 06:26 PM
rsjohnsn's Avatar
rsjohnsn
front end noise
Here is a copy of what it says:
Technical Service Bulletins Summary
Make: FORD TRUCK
Model: F250 SUPER DUTY
Year: 1999
Service Bulletin Number: 13148
Bulletin Sequence Number: 609
Summary Description:
SOME VEHICLES MAY EXHIBIT A FRONT SUSPENSION SQUEAKING NOISE. *TT
This is all I could find.
Scott
Old Jan 15, 2002 | 12:21 PM
Magyver's Avatar
Magyver
front end noise
Thanks for the info guys. I am checking on the service bulliten.
I hav also heard locally some others have this isssue but no
resolution yet
Magyver
I spend way too much time reading this board.
Old Jan 15, 2002 | 01:05 PM
landyacht's Avatar
landyacht
front end noise
I had the same problem, and had the TSB work done on my truck. If I remember correctly, it's adding new isolators between the leafs. I'm also pretty sure they fell off at some point in time. I don't remember what it looked like after the dealer did the TSB, but there were no isolators there when I installed the leveling kit 2 weeks ago.
Old Jan 15, 2002 | 04:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
front end noise
>first.
So, Les and the boys, that is exactly what I was thinking. I can even see evidence of sway bar movement on the bar itself due to wear marks. But what does the technical jerk do?? He changes my upper and lower ball joints. I will see tomorrow morning if this did the trick. He "ran" BOTH TSB's for front end noise and sway bar noise and stated that neither of those were the culprit. We'll see..... :-X23
Old Jan 16, 2002 | 12:21 PM
Monsta's Avatar
Monsta
Sit. Stay.
front end noise
Daggum kid was right!! The noise is gone. Musta been them ball joints.
The noise was most prevelant when hitting bumps that would cause the front springs to extend say maybe 2-3 inches. It wouldn't do it on smaller bumps nor did I notice/feel any clunking that I usually associate with worn ball joints.
It was 28 degrees out this morning when I took my son to school, I made sure I hit all the bumps that I know would cause that sound. No such luck ,the kid who looked like he graduated junior high school the same year my truck was made, fixed it.
So, I guess it's worth a check, Magyver.
Old Jan 16, 2002 | 01:28 PM
NoMo's Avatar
NoMo
front end noise
Are those the new "greaseable" ball joints?
Old Jan 16, 2002 | 02:46 PM
Monsta's Avatar
Monsta
Sit. Stay.
front end noise
Nope.
Old Jan 16, 2002 | 03:17 PM
powerstroker250
front end noise
As you found out monsta, the stock ball joints are junk also. I don't think Ford has put a decent balljoint on a truck since the 70's. Even the IFS had bad balljoints, I know, I replaced them on two previous truck I had.
Les
