Sponsored by: Auxito
Battery light comes on
Old Feb 21, 2004 | 01:37 PM
rleptrone's Avatar
rleptrone
Question Battey light comes on
Hey Everybody!
Quick question. I have a '99 F-150 Ext-cab 4.2L V-6. I've noticed recently that whenever I stomp on the gas hard whether from a complete stop, going uphill or merging onto the interstate and the RPMs hit about 3000 or higher between shifting gears, my battery light will flicker on. When the tranny shifts the light goes out.
I am woner if it is telling me that I have a weak battery or a faulty alternator. Anybody have any thoughts?
Ralph
Old Feb 21, 2004 | 03:37 PM
renty14's Avatar
renty14
I have the same problem on my 98 4.6 and when researching the problem I found the gerneral consensus to be a bad alternator. My truck still runs fine right now though, and it only comes on when I floor it.
Old Feb 21, 2004 | 06:11 PM
grizz5675's Avatar
grizz5675
sounds like to me a loose serp belt causing the belt to slide over your alternator pulley until you step on it causing the serp belt to tighten and grip the pulley...................just a thought
Old Feb 21, 2004 | 08:32 PM
50th ann's Avatar
50th ann
Change the belt. It could be the orignal one. I just changed mine at 116,000 miles.
Old Feb 22, 2004 | 09:06 PM
renty14's Avatar
renty14
what belt did you use? Gator belt?
Old Feb 23, 2004 | 05:06 AM
pro3qtr's Avatar
pro3qtr
My light comes with both old and new belt.
New belt is a Gator back by goodyear
Old Mar 8, 2004 | 09:02 PM
Firefighter 1406's Avatar
Firefighter 1406
When I bought my 97 with 94000 on it did the same thing and I had the dealership replace the altenator and the problem was solved.
Old Mar 8, 2004 | 10:34 PM
MJEmerson's Avatar
MJEmerson
sounds to me like the belt is slipping, or the alternator is on te way out...I would say try changing the belt first, if it has not been done. check the tensioner pulley also...as well as the other pulleys.
are there any other signs of alternator probs...like dimming lights, hard starts, or other electrical probs?
Old Mar 8, 2004 | 10:41 PM
BrianA's Avatar
BrianA
A possibility ????
https://www.ford-trucks.com/forums/s...hreadid=213835
Old Mar 13, 2004 | 06:43 PM
agreder's Avatar
agreder
Had the same problem on a 99 F150-5.4. Got so bad the light stayed on and battery started to drain. After replacing the alternator and still not getting 14+ volts to the battery, started really checking things out and found bad fuse for the 12 volts that supplies the built in regulator on the alternator. Put a new fuse in but still had battery light until we wiggled the fuse in it's socket. Tightened the prongs for the fuse and has been fine ever since. Theory is, the connection was marginal and whenever it was stressed, it would break connection causing the regulator circuit not to work and then the blinking light and the fuse finally blew probably from slight arcing at the poor connection. Before replacing the alternator, check for a loose fuse in the fuse block on the driver's side inner fender. Not sure what fuse number but was a 20A on ours and is probably the same on yours. Owners manual might have a fuse ID for it.
Good luck!
A. G.
Old Mar 15, 2004 | 09:51 AM
FourthFordTruck's Avatar
FourthFordTruck
Same problem. Only now, since I went from
255/70R16 to 265/75R16 the other day,
the light stays on most of the time the vehicle
is moving, whether accelerating or not.
When I'm sitting still it doesn't come on.
There does appear to be some dimming during
acceleration and also when trying to open both
power windows at once, the window motors bog.
I'll look at the brush pack and alternator first,
unless someone tells me different.
'97 F-150 Supercab 4.6 127,500
'99 F-150 Eddie Bauer Expedition 5.4 85,500
Old Jun 19, 2004 | 05:15 PM
pro3qtr's Avatar
pro3qtr
So what is the fix??
ALT checks out fine, new belt, tensioner.
Still stumped !
Old Jun 21, 2004 | 09:11 AM
FourthFordTruck
My alternator was bad. The brush pack was almost non-existant.
I could have tried just a new pack, but since I had it off, and
didn't want to take it off again if it weren't the pack, I did the whole thing.
Replaced with lifetime warranty alternator from Autozone.
