Aerostar Ford Aerostar
Blowing Lukewarm air!HELP!!
Old Feb 21, 2004 | 11:55 AM
Hammerhead's Avatar
Hammerhead
Hi again everyone.. well I got one week off of the fix it site. Okay now another problem with the heat. November I replaced the heater core,hoses, thermostat in January. All was well until about yesterday! The weather is mild here now and I have a Haynes manual finally. Good news! The new problem started suddenly yesterday. The van seems to have a bit of a ruffness when I am on the highway or in the city. It sounds like it has a small hiccup. I think it may be the wetness now but I'm not sure. The biggest new problem is that it suddenly started to blow luke warm heat after I let it sit a couple of hours at the doctors office. The engine temp is staying on below cold but the vents are not blowing cold air. There is no anti-freeze leak and no anti-freeze blowing up at all. Checked the hoses. Good. Checked the anti-freeze hose.Good.The van ran a bit rough. No stalling though. Starts good. Help! Maybe it is that the thermostat has stuck? I paid a few bucks more and got the thermostat that has a safety on it. It won't stick open (i think open) anyway it is that way because that way the van can't overheat if it fails. My only thought is that it is failed. What should I check next? I am at a loss. Thanks in advance for the help. You guys are always so great. Saved me a bundly already.
Old Feb 21, 2004 | 12:26 PM
Timothyap5vm's Avatar
Timothyap5vm
Okay, about the hiccuping problems, try replacing the sparkplug wires.
And about the lukewarm heat, try replacing the thermostat.
Hope this solves it.
Old Feb 21, 2004 | 12:30 PM
Beast12's Avatar
Beast12
I would agree with that. Also, maybe check your distributor cap to see if there is any moisture. When you buy a new thermostat place it in boiling water to see what temperature it opens at. You did buy a failsafe thermostat. Which means if it fails, it will stay open so your engine does not overheat.
-Matt
Old Feb 21, 2004 | 12:41 PM
Hammerhead's Avatar
Hammerhead
Hiccups and chills..
Thanks all, will check both and get back to ya.
Old Feb 27, 2004 | 04:27 PM
johnwa's Avatar
johnwa
definately a thermostat partialy stuck open or you picked up a thermostat that is low temp, when reading the book at the store on which thermostat to buy get the 192 deg. fail safe thermostat is garbage, (money grab) get motomaster
tonyford
1983 - 2012 Ranger & B-Series
31
Nov 9, 2019 02:28 PM
paerhardt
21
Dec 13, 2015 10:55 PM
fred_79f250
15
May 19, 2012 12:24 AM
jchamb11
24
Sep 30, 2011 06:56 AM
mholota
Nov 1, 1999 09:15 PM
