i have that gunk motor flush stuff and before i use it i want to make sure its safe. ive heared that it can damage your engine, but i heared that if you use it right it will do its job with no damage. anybody ever tried it?
i used one once in a chebbie 305 it didnt do anything bad to it. later oil changes seemed to have less crap in them. u might try marvel mystery oil for the same purpose
I have tried it and the only bad thing I can say was it cleaned around my valev guides so well that my old LTD now smokes pretty bad. Had I to do it over again I would not use it. Also will cause leaks if sludge is what is keeping you seals from leaking. If it is an old car and has a good bit of sludge I would pull the valvecovers and make sure the oil return holes in the head are clean and leave it alone. Might try some Autorx as it is much milder.
Originally posted by seldont I have tried it and the only bad thing I can say was it cleaned around my valev guides so well that my old LTD now smokes pretty bad. Had I to do it over again I would not use it. Also will cause leaks if sludge is what is keeping you seals from leaking. If it is an old car and has a good bit of sludge I would pull the valvecovers and make sure the oil return holes in the head are clean and leave it alone. Might try some Autorx as it is much milder.
I recommend you run an Auto-RX treatment to recondition the seals. It works wonders for start-up smoke and eaking seals.
