Sponsored by: Real Truck
interior light / door ajar problem
Old Feb 20, 2004 | 09:21 PM
99F250_V10's Avatar
99F250_V10
Well,l I got the truck. It sure is nice. I was hoping to get some help on an issue with the idiot light that reminds us of the door being a "ajar" .
Seems that after a couple of times going in and out of the truck the door ajar light stays on. I am a superintendent for a home builder in and out of the truck alot. So the other day the light stays on. Then commng to a stop (applied brake) and the interior light pops on ( this has happened a couple of times).
So I check the fuse panel pressing and wiggeling. Seemed to have "fixed" it. No not really, it came back. So now I have removed the 10amp fuse (no indication of failure) for the interior light. Checked some other fuses they all seem to be ok. So now what?
Here's the kicker...I have had the truck for about 10 days. This started 2 days ago, moments after the truck was inspected. Seems the 3rd brake light was out so they replaced the bulb.
I'm in the dark.
Thanks in advance for your suggestions.
-rw
Old Feb 20, 2004 | 09:32 PM
HeavyAssault's Avatar
HeavyAssault
Try spraying the door latch with WD40, open and shut the door a few times. This has been posted before with good results.
Old Feb 21, 2004 | 09:49 AM
Bob Ayers's Avatar
Bob Ayers
Spray the latch mechanism in the door with WD40 (just to clarify)
Old Feb 21, 2004 | 09:54 AM
HeavyAssault
Yes that is correct.
Old Feb 21, 2004 | 12:15 PM
M1Tanker's Avatar
M1Tanker
That does work by the way. I have a 95 Mazda B-2300 and that stupid light and bell stayed on every time I got in our out of the truck. First time I just unplugged the switch inside the door. Next time I just flooded the latch with WD-40 and it solved the problem.
Old Feb 27, 2004 | 07:35 PM
99F250_V10's Avatar
99F250_V10
WD40 works again
Just wanted to thank the guys for their replies about my dash light problem. The WD40 has been working since last Sunday.
Seems I need about 20 more posts before I can Email individuals.
Old Feb 27, 2004 | 10:31 PM
grnsteel's Avatar
grnsteel
This fix is too simple...but it worked. My bed light and interior light now turn off. Saved me alot of electrical work. Thanks.
Old Feb 29, 2004 | 05:28 AM
markethopper's Avatar
markethopper
I had the same problem for over two years. It was fixed with a few squirts. Thanks.
Old Feb 29, 2004 | 09:54 PM
V10 Eddie's Avatar
V10 Eddie
My 99 just started doing this today, thanks for the tip. I'll spray mine down.
Old Feb 29, 2004 | 10:06 PM
christaylor's Avatar
christaylor
Re: interior light / door ajar problem
Originally posted by 99F250_V10
I am a superintendent for a home builder in and out of the truck alot. So the other day the light stays on. -rw
What builder do you work for? I am a supervisor for Ryland in
Harford County.
Chris
Old Mar 1, 2004 | 09:05 AM
Vandervk's Avatar
Vandervk
My 2003 Explorer XLT does the same thing. When the door ajar light stays on, so do the interior lights and the lights under the sideview mirrors. It was a huge pain, but once I tried the wd-40 it only happens about once or twice a month instead of every day. It is still a pain, but not nearly as bad as before.
Old Mar 5, 2004 | 08:32 PM
redrdr67's Avatar
redrdr67
Big thanks from me too. Great help on this forum.
