Sponsored by: Real Truck
installing mirrors
Old Jan 31, 2002 | 03:31 PM
easyday77's Avatar
easyday77
Post installing mirrors
well, i found those telescoping mirrors i was looking for. thanks to everyone for the info. now, i pulled the black panel off the upper corner of the door and unbolted the existing mirrors, but i can't seem to find where the wiring harness is. from where the wires leave the door frame, i can't tell if the harness would be behind the door panel or not, and i was wary of starting to tear the panel off if i didn't need to. does anyone know where the wiring harness would be located on a 2000 F250? Also, if i do have to take the door panel off, i didn't see any screws/mounting equipment. does this panel just pop out in the same way the one on the upper corner does?
Old Jan 31, 2002 | 05:01 PM
charlesvalentine's Avatar
charlesvalentine
installing mirrors
Well to remove the door panels pop off the little red reflector thing on the bottom half of the door. Then remove the screws that are exposed. Next, remove the screw at the bottom corner of the door.
Then, pop up the plastic piece that has the pwr windows and door lock switches. I think there is a screw there also.
Now the door should lift up and then out. It is important to lift up as there are tabs that you can break if you do not.
Old Jan 31, 2002 | 07:11 PM
charlesvalentine
installing mirrors
Just remembered... There are a couple rubber plugs on the inside of the door where the mirror is. You should be able to loosen those and remove/install the new mirrors. You should not have to remove the door panel to do this.
Old Jan 31, 2002 | 11:00 PM
abendx's Avatar
abendx
installing mirrors
easyday... what is your e-mail addr?
i bought mc's mirrors from him and he sent me install instructions.... i can forward them to you.
Old Feb 1, 2002 | 11:31 AM
easyday77's Avatar
easyday77
installing mirrors
my email is easyday77(No Email Addresses In Posts!)
thanks cous
Old Feb 1, 2002 | 01:42 PM
redranger1's Avatar
redranger1
installing mirrors
