Sensor/Idle issue??
Old Feb 20, 2004 | 01:38 PM
Getting Frustrated's Avatar
Getting Frustrated
Sensor/Idle issue??
My mechanic has been working with a Ford technician on my 99 Ford Explorer for the past month trying to fix an idling issue I have. (Mainly in the colder months)
When I start it, it revs very high than drops very low - there are times when it will stall out. It seems to drive ok - a little rough - but ok, check engine light is on and all sensors have been checked.
Does anyone have any experience or advice?
Much Much Appreciated.
Old Feb 20, 2004 | 02:00 PM
christaylor's Avatar
christaylor
Hey Welcome to FTE. There are many knowledgeable people here you may want to post this in the Explorer forum to get an answer.
Old Feb 20, 2004 | 02:04 PM
duff man's Avatar
duff man
what are the codes? (DTC) if check engine light is on then there will be a DTC
Old Feb 20, 2004 | 10:46 PM
nhfire 77's Avatar
nhfire 77
Yea the lights on there is a Diagnostic Trouble Code (DTC) Get someone who has a reader/scanner tool or a shop to find out what it is, if you cant find out what it means there is a sticky thread posted at the top of the listing here with ideas/possible fixes. Also there is the whole gambit of normal fixes like your MAF, IAC, EGR, DPFE. The most common(and it sounds like what ive experienced was the IAC valve see the sticky on that all the way at the top of the threads in here
Old Feb 20, 2004 | 11:53 PM
nhfire 77's Avatar
nhfire 77
BTW- If you have had mechanic working on your Truck for a month and he still have no idea whats wrong--GET A NEW MECHANIC!
Old Feb 21, 2004 | 12:06 AM
ltfox's Avatar
ltfox
Leaking lower intake gaskets have been a big problem on th 4.0 explorers. If you've already check the IAC I go their next. I had a similar problem with my 2000 and this was my problem. Run smooth now on cold starts and no more CEL.
Old Mar 14, 2004 | 02:14 PM
GWC1946's Avatar
GWC1946
TPS
Had a similar problem with my 91 EXP. It turned out to be the Throttle Positioning Sensor. That fixed it.
Michael Mohr
Feb 7, 2017 05:03 PM
Michael Mohr
New Member Introductions
Jan 21, 2017 05:32 PM
ng19delta
21
Feb 23, 2016 04:48 AM
split2nd
May 2, 2012 07:48 PM
hgbyrne
1997 - 2003 F150
Apr 7, 2011 02:51 PM
