Sponsored by: Innova
Please help with Cd player problem
Old Feb 19, 2004 | 11:14 PM
mike_23us's Avatar
mike_23us
ok boys i got a question for you'll ok i have a 91' ranger and i put a sony xplode head unit in it, but i have a problem when ever i shut off the truck and then i restart it it earsies everything like the time and ect. soi have to restet it everytime, the wires from the truck have a line named memory output but if i run that it will keeep the cd player on contantly please help need help so if you know anything please post
Old Feb 20, 2004 | 12:17 AM
acerockola77's Avatar
acerockola77
Re: Please help with Cd player problem
Are you refering to your 12V constant? You should have a yellow and a red wires, one is the Ignition wire, the other is the 12V constant. Both of them should be hooked up. If you hook it up right, it shouldn't be on constantly.
Old Feb 21, 2004 | 03:13 PM
mudyma5's Avatar
mudyma5
Talking cd problem
ok,you should have a yellow and red wire for power. one wire is your constant that should go to a constant power source such as headlight fuse under the dash and one should go to a fuse line that turns off with the car like your wiper fuse that way your radio has a constant power source...
MBBFord
2004 - 2008 F150
Nov 12, 2014 04:14 AM
trmann
Aug 7, 2012 11:40 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Sep 26, 2009 12:06 AM
smoore79
Oct 22, 2008 02:32 PM
Mitzilplic
Feb 25, 2003 09:42 AM
