87 ranger not getting fuel
Old Feb 19, 2004 | 08:27 PM
lakahahahman's Avatar
lakahahahman
ok my 87 ranger 2.9 will run good for awhile the start to sputter really bad
then stall and wont start again
when i turn key on you cannot hear fuel pump prime anymore
not getting pressure but when i press on schrader valve it sounds just like a bunch of air
there is a couple relays under a cover hehind battery a black and green one and a black and brown one.
i changed both and no fuel
the black and brown relay has two yellow wires running into one if i hook direct power to this from battery the green one clickes for about three seconds (i think this one is fuel pump relay green one) fuel pump goes and truck will start, but still start sputtering and die
if truck sit for a length of time it will start fine
i am in dire straights here over this, as i have a 4x4 run to go on this saturday with a bunch of other people
any help would be greatly apreciated
Henry
Old Feb 19, 2004 | 08:38 PM
Dealford's Avatar
Dealford
After the truck sits for a while, it starts fine? Check all the grounds. A poor ground will cause all of the components in an electrical system to heat up. I believe an overheated relay will stay "disengaged" until it cools down?
Old Feb 20, 2004 | 01:54 AM
77redf250's Avatar
77redf250
is the tank full??this seems obvious but you'd be surprised how many vehicles get towed on empty. try banging on the tank with a rubber hammer while a buddy tries to start it you might have a dying fuel pump.
Old Feb 20, 2004 | 09:47 AM
QRFleader's Avatar
QRFleader
If its a 4x4 try changing both fuel filters. The book says that they are ment to last the life of the vehicle but we all know how that goes.
Old Feb 20, 2004 | 10:20 AM
lakahahahman
but if i jumperwire the relay then the fuel pump kicks in and the truck will start
where are fuel filters located yes it is a 4x4
i thoguht there was only one filter
when i turn on the key the fuel pump does not kick in this is my problem
Old Feb 20, 2004 | 10:31 AM
Ken00's Avatar
Ken00
Drop me an email and I can send you the wiring diagram for the fuel pump. Please remind me what you need.
Old Feb 20, 2004 | 10:39 AM
lakahahahman
thanks ken i have sent you an email
Old Feb 20, 2004 | 10:45 AM
Ken00's Avatar
Ken00
You have mail.
Old Feb 21, 2004 | 09:33 PM
lakahahahman
ok well i have it narrowed down to wiring now
where the relays are by the airbox
when i leave key on and wiggle the main harness around down there it starts to cycle my fuel pump on and off
so now i just have to trace the wire that is bad LOL
there is a lot of wires
