1978 - 1996 Big Bronco
79 bronco motor question
Old Feb 19, 2004 | 04:56 PM
flaireside95's Avatar
flaireside95
Question 79 bronco motor question
i just got a motor fro my bronco. right now its got a 351m in it and i just got a 351w this motor should mount right up right? cause there all the same block pretty much its just the emissions and **** on it so this should work right?
Old Feb 19, 2004 | 05:00 PM
79 Trailer Special's Avatar
79 Trailer Special
Sorry to give you bad news but no the "W" block will not bolt up where a "M" was. The "M" motors have the big block bellhousing bolt pattern where the "W" uses the small block pattern. The only other motors that will bolt up to the trans is the 385 family, 429's and 460's
Old Feb 19, 2004 | 06:08 PM
flaireside95
damn. thats not good. ur positive about that right. is there like a mounting kit i could buy
Old Feb 19, 2004 | 08:42 PM
79 Trailer Special
There may be adaptors available but I would not recommend that and the price would not be cheap. Maybe you could sell the Windsor and pick up a M or a 460 with the money.
Old Feb 19, 2004 | 09:18 PM
oldhalftons's Avatar
oldhalftons
the 351W shares a bellhousing patern with the 300 I-6, 255 V8, 302, 351C and one of the V6's (i think its the 3.8L)
your 351M shares a bellhousing bolt pattern with the 370, 400, 429, 460 and the 6.9L IH diesel.
Old Feb 19, 2004 | 09:50 PM
steell's Avatar
steell
I think it's the 4.2 (Ok, I'll be honest and admit I just got through reading that elsewhere)
Old Feb 19, 2004 | 09:54 PM
oldhalftons
Talking
LOL
just reading it is cheating
Old Feb 20, 2004 | 12:35 AM
phyxius's Avatar
phyxius
actually it is the 3.8 i just changed one for a 302 due to the head gasket probs with the 3.8's
Old Feb 20, 2004 | 12:37 AM
ohrtman19's Avatar
ohrtman19
i got an old 351m sitting here not being used but it needs a set of heads other than that it is a great motor
Old Feb 20, 2004 | 07:13 AM
Pentekno2's Avatar
Pentekno2
You probably wouldn't want to drop a 351w into a 78/79 Bronco anyways, it doesn't have nearly the brute low end that you need to haul that beast around town (I know, Ive had both engines)
Your best bet would be to get yourself a hold of a 351m block, they're easy enough to find at junkyards and even right here on FTE. Then build it to a 400, which is also easy enough, youcan find more information on that here in the 351m/400 forum, just use the search function, the topic has been beaten to death already.
Good luck!
-Pentekno2
Old Feb 20, 2004 | 10:50 AM
mweeps's Avatar
mweeps
phyxius was that in TBird mustang or Cougar?
Old Feb 20, 2004 | 04:29 PM
Txquadhunter24's Avatar
Txquadhunter24
the 3.8 v-6's can be found in the early 80 trucks. I believe it was a base model made for fuel mileage but was way under powered for fullsizes.
