View Poll Results: Should I switch motors
Switch to the low mileage motor
83.33%
Keep the old one.
16.67%
Voters: 6. You may not vote on this poll
Should I get the new engine???
Old Feb 19, 2004 | 06:52 AM
couleeman's Avatar
couleeman
I currently have 190000 on mine. The neighbor just told me that he has a I-6 from a 91 (my truck is a 92) that only has 70000 miles on it. He also said he would sell it to me for $200-$300.
What do you think? Should I switch out or keep mine. I know I will have to pull mine this year to replace the oil pan so the labour isn't to much of an issue.
Old Feb 19, 2004 | 08:48 AM
cdherman's Avatar
cdherman
Grab the one with 70k for $200, no more. Put it in a corner and wait till the other one blows. Then swap. Could be years before the old one craps out. Of course, if you intend to pull the whole engine to relace the pan (why??) then I guess you could just get it overwith. But 190k is not shot for a 300. Could do a compression test on both engines, infact would be a good idea, before you end up with a worse engine AFTER the swap.
Old Feb 19, 2004 | 10:04 AM
couleeman's Avatar
couleeman
The pan in my truck is starting to rust. I cleaned it off and sealed it from the outside, but I imagine I need to replace the pan sooner or later.
Old Feb 19, 2004 | 10:48 AM
sicbpguy's Avatar
sicbpguy
I would grab that second one and use it later if needed. As far as changing the oil pan: Get a jack under the engine, remove the mounting bolts, jack up the engine high enough to work and block it up with some wood blocks. You should be able to change the pan that way.
Old Feb 19, 2004 | 11:14 AM
Maynster's Avatar
Maynster
I've got 208k on my 300 and it doesn't burn any oil, just leaks it everywhere. I've heard rumors that the 300's in some of the ups trucks have clocked up to 1 million miles on them. If its got oil and it doesn't overheat you got no problems.
Mayne
Old Feb 19, 2004 | 12:37 PM
couleeman's Avatar
couleeman
Mayne
That is my debate. Mine doesn't burn any oil, just leaks a little from the oil pan. I was debating rebuilding the one with only 70,000 miles and then switching them out. But then I am looking at more than the $200-$300 for the engine.
Old Feb 19, 2004 | 02:04 PM
rhetor's Avatar
rhetor
well if it were me, i would buy the 300, and keep it sitting in the garage. Then i would slowly rebuild it when i had the spare cash, and put a little more tq in her too!
i wouldn't worry about your old 300 crapping out on you any time soon. When 300s go, they have horribly long, drawn out deaths, starting at 250-300k and going till... well i guess they never do die do they?
Old Feb 19, 2004 | 04:36 PM
1982fordf100's Avatar
1982fordf100
The 300 in my 1982 F100 has 312,000 miles on it. It starts and runs fine, but when you let the clutch out and give it gas you can hear alot of ticking and chattering from the valve train. No rod knock though. It sure has a loss of power though.
Old Feb 19, 2004 | 05:37 PM
cdherman's Avatar
cdherman
If you want to rebuild an engine becuase "its fun" and you'd like to do it yourelf, then great. If you want to build a screamer and need to throw a bunch of performace parts into it, then fine. But these days, rebuilding an engine to stock specs is best left to a factory engine rebuilder. A long block from Jasper is like $1200. You cannot do what they all do for that, if you count your labor for much, and if you have to pay a machine shop to do much of anything. JMHO
Old Feb 20, 2004 | 03:59 AM
Patrick_PDX's Avatar
Patrick_PDX
70,000 miles isn't even broke in yet. Just put it in the corner of the garage and install it when the old one gives up in 15 or 20 years.
Old Feb 20, 2004 | 01:35 PM
gatesj's Avatar
gatesj
Just be careful with the air injection stuff. Make sure that if your truck has the air injection lines to the head just over where the injectors are that your used lo-miles motor does too. I know my '91 does not have the holes but a replacement '92 motor I bought does. No problem for me, I can just plug them but going the other way is more difficult, you need a different head, it's a different casting.
Old Feb 20, 2004 | 01:43 PM
broncobillybob's Avatar
broncobillybob
yeah, get the engine and sit on it. I'd do my homework and make sure the swap will be as painless as possible, lines, air sensors, etc. You know what you are talking bout though. Good luck. -wb
Old Feb 20, 2004 | 05:16 PM
ftwfred's Avatar
ftwfred
Thumbs up I have a solution
Buy the old one(1991) for $200, Swap it out and I will give you $150 for your old one!! I need the core. Fan to Flywheel with manifolds. When can I pick it up?? OR buy the 1992 for $200 and I will give you $300 for it, Then you will have no $$$ in the repairs to your truck..
It is a no lose situation...
ftwfred
