Sponsored by: Real Truck
NP271 opinions
Old Feb 8, 2002 | 07:38 AM
Monsta's Avatar
Monsta
Sit. Stay.
NP271 opinions
>New Venture was formed when GM and Chrysler decided to work
>together to design and build transmissions in the mid 90's
>(hence the name, it was a "new venture" since most large
>corporate companies usually refused to work together). They
>bought and now own New Process Gear and Muncie, both older
>companies.
And now I know!! Daggum, I don't think I've learned this much from one thread! Thanks guys!
Old Feb 8, 2002 | 11:05 AM
spartamouse1's Avatar
spartamouse1
NP271 opinions
excellent, boy's know your transfercases i see now. here i was thinking a electric shift had a slightly lower gear but now i see 271 manual shift 273 esof. 1 meing manual shift and the 3 being electronic.
parts man
Old Feb 9, 2002 | 11:12 PM
J.C.'s Avatar
J.C.
NP271 opinions
Tony
You don't say what year truck you have. I think the bad thing about the np205 is the low range. The BG you have has a pretty good low range. Without looking it up I don't know for sure but I want to say it's 2.62:1. The 205 was used on Dodge, GM, and Ford trucks over the years. After a quick web search I found a couple good web sites you might want to check out. http://www.offroaddesign.com/NP205tech.htm
http://www.ford-diesel.com/contents/getitems.php3?Charlie%20Aaron's%20Truck
http://4wheeldrive.about.com/gi/dynamic/offsite.htm?site=http%3A%2F%2Fwww.medicine.wisc.ed u%2F%7Emrm%2Fbronco%2F
As for swapping in the NV271 I'll have to say maybe. The 4R100 in the super duties are for the most part just updated E4OD's so if you have an E4OD maybe you'd get lucky and it would bolt right on? I really don't have a clue though.
On a side note, I was just reading Dodge will be going to the NV271 and NV273 for 2003. Anyone know what the use in the new Chevy trucks?
Old Feb 10, 2002 | 12:14 AM
TonyG's Avatar
TonyG
NP271 opinions
>Tony
It's an '87 F350 Crew with a ZF-5 onto a 460 with 3.55 gears.
After a quick
>check out\
Thanks, I'll check them out.
What is the current v10 tranny? I think it's a ZF5 47 or something like that. There is a ZF42 also which is I think what I have. I think probably the ZF47 has the V10 and 5.4 pattern while the 42 had the 460 pattern? But then I'm just guessing, and really don't have a clue either :-X11 Maybe someone can help us out.
Tony
Old Feb 10, 2002 | 09:59 AM
Gubby's Avatar
Gubby
NP271 opinions
According to the May 2001 issue of Peterson's 4wheel and Off-road mag., the NVG 271(3) transfer case, although a chain drive, is much stronger than the NP205 gear-driven case. I loved my 205-driven 4x4, but I'm not against progress when reliability and durability are there. Maybe the chain-driven T-case is a practical improvement. I understand that the 203 and the 208 did not measure up. Jim
Old Feb 11, 2002 | 11:56 AM
busdriver1's Avatar
busdriver1
NP271 opinions
Tony,
Early years with the 460 and the ZF had the s5-42. This is probably the tranny you have. Later years of the 460 ZF combo had the s5-47. I think the s5-42 and s5-47 would have the same tranny/t-case interface and, thus, any t-case that would bolt to a s5-47 should bolt to an s5-42. I believe also that '99-'01 SDs with the V-10 came with the s5-47. So you probably should be able to bolt the NVG271 right up. I am speculating here though, so please don't hold me liable.
Neil
P.S. Jim Feuling's web site was recently updated, but he still doesn't have any more info on his 460 heads.
Old Feb 11, 2002 | 03:51 PM
JoeBoost's Avatar
JoeBoost
NP271 opinions
Brettboat
Mar 29, 2017 10:38 PM
CPB1
Oct 22, 2016 06:47 PM
wils3825
Jul 11, 2016 01:03 AM
dabeef
Apr 20, 2016 04:47 PM
Texasj10
Apr 3, 2002 11:12 PM
