Sponsored by: Real Truck
Lift Manu's
Old Feb 18, 2004 | 09:28 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Question Lift Manu's
Alright, Don't yell but I did search the Susspension form and didn't find what I wanted.
Here's the deal: I want to lift the truck 3"-4" with susspenion lift but I like to know what the guys running the '99 to 04' F250 SD are using.
What brand are you guys buying, rancho, skyjacker, superlift....?
How much does it affect the ride of the truck?
Do the drive shafts need to be modified?
Most importantly, can I do this with some help from friend? (I know my way around a garage a bit)
I thought it would do better in this forum since this is where the big boys play.... Thanks Mike
Old Feb 18, 2004 | 09:37 PM
02superstroker's Avatar
02superstroker
Superduty lifts are some of the easiest to install. With moderate tools you can get an install done in your driveway in a day. Just be careful, use your friends help, as the springs, axles, etc are very heavy.
Most (about every single one) company offers that size lift for the superduties.. so look around at what people are satisfied with.
Here is a good thread on different brands being used by users of this site:
Different Brands
Old Feb 18, 2004 | 09:41 PM
DCSpecial's Avatar
DCSpecial
Run a search in this forum for "lift poll" or something like that, to see what brands are being run.......I think over 60 people voted.....
How ride is effected depends on the brand and type of lift. A Hanger and shackle lift will ride better since your stock spring are retained so there is no increase in spring rate...........and by adding better shocks like the Bilstein 5100s your ride is improved.
Driveshafts do not have to be modified. If you have a two piece rear driveshaft you'll most likely have to shim down the carrier bearing some.
Yes, you can install the lift with the help of a friend as long as you have a heavy duty jack, a heavy duty set of jack stands and of course air tools are nice.
Hope this helps.
Edit: looks like 02superstroker posted the list to that poll
Old Feb 19, 2004 | 04:51 PM
F-250 Super Duty
Thanks guys, some times it's hard to search some things due to all the different wording...
02suprstroker: thanks for the link...
Mudbogginsouthernboy
Aug 10, 2013 12:10 PM
f250rangerexplorer
Jan 18, 2013 12:32 AM
quadcam
Oct 17, 2010 10:05 PM
greenmachine1
Feb 4, 2006 02:17 PM
