Rear end swap
Old Feb 18, 2004 | 03:52 PM
Maineiac's Avatar
Maineiac
Rear end swap
I have a 88 302 5spd with a 355 rear gear and was thinking of swapping to a 308. Has anybody done this ? Is there any specific year 8.8 to avoid? Is the truck 8.8 unique? OR will a mustang one swap in? Thanks in advance
Steve
Old Feb 18, 2004 | 06:23 PM
Lou Braun's Avatar
Lou Braun
A 355 rear end is about standard for an F-150 with a 302 engine (many folk would prefer 411s). You might not be pleased with performance after going to 308 gearing since the 302 does not make lots of torque at low speeds.
Changing tire diameter is an easy way to get the same effect as changing rear end gears. Might be worth thinking about.
Lou Braun
Old Feb 18, 2004 | 07:00 PM
acerockola77's Avatar
acerockola77
I don't think it's worth it, the gas mileage will not be that signifigantly different, and the 302 is probably going to feel underpowered with 3.08s, IMO.
Old Feb 19, 2004 | 09:10 AM
Maineiac's Avatar
Maineiac
Thanks for the info may have to rethink this it was not really a gas millage idea it was more that it seems to be screeming at 60 mph (2100 rpm). It also seems like I have to shift early (going into 5th at 45) but maybe I am not just used to it. ( I just traded an 81 chevy 350 auto for this truck)
Thanks
Steve
Old Feb 19, 2004 | 09:38 AM
JeremyH's Avatar
JeremyH
It would probably be cheaper to get a larger set of tires.....
Old Feb 19, 2004 | 10:05 AM
blu's Avatar
blu
Whats screaming at 2100 RPM? What RPM you shifting at ...that seems pretty low.
Old Feb 19, 2004 | 11:01 AM
Maineiac's Avatar
Maineiac
I shift around 2000 and I know that is not high just sounds like it could just be the exhaust.
Steve
Old Feb 19, 2004 | 11:04 AM
Maineiac's Avatar
Maineiac
BTW I am allready running 31x10.50 15" on it
Old Feb 19, 2004 | 11:22 AM
RTM's Avatar
RTM
I have larger tires on my 89 with a C6 and 3.55 gears and I run close to 3k on the tach will driving around 70mph. Thats screaming to me. I plan on installing a ZF this spring to bring the rpm's down and hopefullt imptove my mileage.
Old Feb 19, 2004 | 01:08 PM
Maineiac's Avatar
Maineiac
ZF is a different ratio than a m505?
Old Feb 19, 2004 | 01:22 PM
msu_fan's Avatar
msu_fan
I have a 308 rear end in my f150 w/302, my biggest complaint is that it spins really bad.
Old Feb 19, 2004 | 01:26 PM
Maineiac's Avatar
Maineiac
Do you have manual or auto? what kind of rpm are you turning at 55?
Old Feb 19, 2004 | 08:32 PM
paul812's Avatar
paul812
a 302 isn't screaming at 2grand. has any of the factory intake been modified/altered? intake noise can be a problem, as well as other engine/body or some resonance at certain rpm's. my '91 w/e4od is just hitting the 2k mark at 70 mph! very quiet, but of course it's in overdrive, but also have 355 rear. hows your fan clutch? i would strongly recomend checking other sources of noise before tearing into the rear end. that's an expensive job unless you've done it before & want to tackle it. my 2cents worth...pross
Old Feb 19, 2004 | 08:43 PM
StrangeRanger's Avatar
StrangeRanger
The Mazda M5OD has an OD ratio of 0.80:1, the ZF has a 0.76:1. Not much difference in OD ratio, a lot in tranny strength. RTM is currenty running a C6 which has a 1:1 top gear with no OD.
