C6 Oil Pan
Old Feb 18, 2004 | 01:26 PM
hdgapeach's Avatar
hdgapeach
C6 Oil Pan
Are there any aftermarket cast aluminum (or other cast metal) oil pans with a drain plug avaliable out there? If you know of one tell me the supplier's name so I can get one. The pan I have (stock) is about worn out. I can't get the edges to seal anymore. It leaks like a screen door! I've peened the holes so many times to flatten out the edge I think the metal is fatigued. It's on a 77 F150 4X4 351M C6. Thanks for any info you guys/gals list.
