flywheel ring gear
Old Feb 18, 2004 | 07:00 AM
greythorn3's Avatar
greythorn3
flywheel ring gear
i have a 77 f250 replacing the clutch and the new used flywheel i have may need the ring gear replaced, does it press on and off, do i need to head it and slip it off then heat the new one and slip it on? not quite sure how it goes on, didnt even realise it was a seperate piece tell i seen you can get them seperate on checkers website.
Ray T
AK
BLURR
Old Feb 18, 2004 | 07:52 AM
GLR's Avatar
GLR
I used to take a chisel and spllit the gear between the teeth, then heat up the new one to drop on the flywheel. Sometimes on problem jobs we would spot weld the gear to the flywheel in 3 tried to get equaly spaced areas. This does throw the balance off a bit. Good luck
Old Feb 18, 2004 | 08:09 AM
greythorn3's Avatar
greythorn3
what if you want to get it off and flip it over without destroying it, and wouldnt head make the ring gear softer so it would get tore up faster? is that how the machine shops do it?
Ray
AK
Old Feb 18, 2004 | 09:08 AM
steell's Avatar
steell
A ring gear is only $19 (for a 4.9) at AutoZone.
I stick the flywheel in the freezer and the ring gear in the oven, goes on easy that way
Old Feb 18, 2004 | 09:19 AM
greythorn3's Avatar
greythorn3
what temp in the oven and about how many minutes? by the way thanks for helpiin im new at this rin gear thing, always had auto and just replaced flexplate they always cheap
Ray
Old Feb 18, 2004 | 09:27 AM
steell's Avatar
steell
400 degrees and about an hour. I leave the flwheel in the freezer overnight
Old Feb 18, 2004 | 10:27 AM
greythorn3's Avatar
greythorn3
thanks again, they really should post that in the tech section
Ray AK
Old Feb 18, 2004 | 11:29 AM
greythorn3's Avatar
greythorn3
i learned they only come off and go on one way today, they go off towards the engine and come back on the same way they went off, there is a lip so it can only go one way.
Ray
AK
Cougar54
42
Mar 23, 2014 01:41 PM
Ctrain
2004 - 2008 F150
Mar 11, 2012 04:14 PM
Voodoo66
Nov 19, 2007 08:15 PM
1982fordf100
Jun 17, 2006 02:02 PM
1981 F250 460
Aug 28, 2004 11:29 AM
