brakes need oomph
Old Feb 17, 2004 | 06:12 PM
gtex's Avatar
gtex
brakes need oomph
I recently replaced the booster and the master cylinder in my project. The brakes still require a good bit of effort on my part. The brakes were completely rebuilt at the wheel level no more than about 2000 miles back. Factory Drum/Disc setup.
I'm running a pretty big cam, but not too big on the duration so the vacuum is actually pretty good. It's 20+ while crusing.
Any ideas?
Old Feb 17, 2004 | 07:28 PM
HillbillyHellcat's Avatar
HillbillyHellcat
CHtopping.com does drum drilling to improve braking performance, as does praisedynobrake.com sell hipo brake kits.
They could be as good as they get. Mine are terrible as well.
Old Feb 17, 2004 | 11:11 PM
Comegetsome's Avatar
Comegetsome
Perhaps a vacuum resevoir canister may help with the bigger cam.
Old Feb 18, 2004 | 03:12 AM
BB's Avatar
BB
What's the vacuum idling in drive while stopped? Easy way to tell if you don't have enough is to put it in neutral next time you coast to a stop and see if it brakes any better.
Old Feb 18, 2004 | 04:46 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the vacuum check valve in the booster. You can get vacuum pumps also. I have used some off old GM vehicles to run cruise controls etc.
Old Feb 18, 2004 | 07:15 AM
starboy's Avatar
starboy
Greg, are you running disc or drum brakes? Brake shoes are not always arced to the drum, and that'll increase your pedal pressure. If there was a drop or two of water in the brake lines that could be sticking a wheel cylinder. You've done a great job on your truck.
