Engine Identification
Old Feb 17, 2004 | 09:41 AM
Santoken's Avatar
Santoken
Unhappy Engine Identification
A friend of mine just bought a '79 F150 4x4. When he purchased it, the previouse owner claimed he did a motor swap to a 460. It's quite a nice truck, and runs great. The other day, while under it checking it all out, we stumbled upon this 'adapter' that is between/over top of the timing cover. This adapter is approx. 2" thick and at the bottom of it is two ports that are plugged. This adapter/plate is directly between the balancer and the timing cover.
We have talked to others and have heard everything from it being a marine engine, an industrial engine, an engine oil cooler with a crankshaft driven pump inside, etc.
While I'm not the most familier with big blocks, I'm at a bit of a loss. Can someone help us identify this engine and what that added cover is?
Kent
Old Feb 17, 2004 | 01:31 PM
Mil1ion's Avatar
Mil1ion
Post the numbers that are cast into the block & heads.
Plus, Photos ?
Old Feb 17, 2004 | 08:53 PM
greenhighboy's Avatar
greenhighboy
Some 68-69 429's had a crank driven powersteering pump. That sounds like what you are describing.
Kent A Tromp
Mar 17, 2014 10:57 PM
Kentwa
22
Nov 17, 2010 07:39 AM
ksvtwin
1983 - 2012 Ranger & B-Series
May 27, 2004 07:02 AM
Hegemon
New York Chapter
Mar 31, 2004 06:42 PM
