Rear Gear ?'s
Old Feb 16, 2004 | 11:44 PM
good 'ol ford's Avatar
good 'ol ford
does this sound right ??
i have a 77 ford f-150 it has a c6 tranny and at 70 it runs at about 32- 3500 rpm i wanted to get i higher gear ratio to lower that a little bit. i rolled under it the other day and the tag on it said that i had a 3.25 which just sounded way to high to me any one have any idea if thats right or how i could tell what it truly is thanx
Old Feb 16, 2004 | 11:56 PM
FordPickup460's Avatar
FordPickup460
There are alot of ring and pinion websites that have a ratio calculator, they are fairly accurate. ringandpinion.com i think
Old Feb 17, 2004 | 04:44 AM
Jerrybo66's Avatar
Jerrybo66
That's about what the rear my ''73 has. Your RPM's seem way too high for 70 MPH. Are you sure your tranny's not slipping?
Old Feb 17, 2004 | 05:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
As a general rule of thumb for a stock tranny about 5-10% slippage is normal. You can find more tranny info in the tranny forum.
Old Feb 17, 2004 | 07:29 AM
Icicle's Avatar
Icicle
A given gear ratios RPM at a certain speed will change with different tire sizes, here is a calculator where you can figure it all out yourself, good luck
Gear Ratio Calculator
Old Feb 17, 2004 | 09:25 PM
good 'ol ford
no i know my tranny isnt slipping, it was rebuilt about 10,000 miles ago and shifts real nice still. and thanx for the caculator websites.
Old Feb 20, 2004 | 10:48 AM
greythorn3's Avatar
greythorn3
the easy way to lower your rpm at 70mph is to put larger tires on it.
Ray
AK
Old Feb 20, 2004 | 07:14 PM
LxMan1's Avatar
LxMan1
According to that calculator, 3.25 gear, 1.10 final drive (to figure in converter slippage), 29" (stock) tires @ 70mph = 2899rpm.
