Sponsored by: Auxito
Superchips 1715
Old Feb 16, 2004 | 09:52 PM
ShAnGo88's Avatar
ShAnGo88
Superchips 1715
I recently purchased a superchips 1715 off of e-bay. I did not know that the tuner vin locked until i read the manual. I havent tried to use it yet. I am wondering if anyone knows what will happen? Will it just not allow me to set a new program or will it set the new program but not read my stock program? Did I get ripped off?
Old Feb 16, 2004 | 11:16 PM
LxMan1's Avatar
LxMan1
I would think that Ken (webmaster) could probably answer that. I'll send him a message.
Jimmy
Old Feb 16, 2004 | 11:24 PM
ShAnGo88's Avatar
ShAnGo88
Thank you Jimmy. Any help or suggestions would be greatly appreciated.
Old Feb 16, 2004 | 11:44 PM
fireball69's Avatar
fireball69
If the tuner was used before and NOT reset it is unusable on another truck. It could have been used and then reset back to factory specs - then it can be used on another truck. The tuner will only work on one truck at a time.
Hook it up to your truck and see if it allows you to tune. If it comes up as tuner is vin locked you got ripped off and I would get in contact with the seller to get it returned. Superchips will not touch it since you bought it off e-bay and not through a authorized retailer. There are authorized retailers on e-bay though.
If it allows you to tune then it is fine, you just won't get the support for superchips in case you want to upgrade to a newer program.
Old Feb 17, 2004 | 12:07 AM
FTE Ken's Avatar
FTE Ken
Echo the above. Also be advised that not only will Superchips not update it/support it if bought through eBay, they only warranty tuners to the original buyer (they will ask for proof) and then only if purchased through a legit source.
Plug it in, it'll let you know if it's locked and will not program another vehicle.
Old Feb 17, 2004 | 05:07 PM
pro3qtr's Avatar
pro3qtr
That SUCKS !!
Old Feb 17, 2004 | 06:35 PM
ShAnGo88's Avatar
ShAnGo88
I tried to plug it in today. It did not say it was vin locked however it would give an error message each time i tried to load a program.
The message was: Error - Check connections!
Im pretty sure i had it hooked up right and had all the correct fuses pulled. Does that message make any sense to anyone?
Old Feb 17, 2004 | 08:41 PM
CPerry's Avatar
CPerry
Try posting this in the computer & tuner forum, you may have better luck there.
Old Feb 17, 2004 | 11:05 PM
wmcnally's Avatar
wmcnally
The 1715 connecter is a very "tight fit" with the OBD II port. This is well documented. Just make sure the "pins" are lined up and don't be afraid to push them together "real good".
Good Luck
