Sponsored by: Auxito
changing headlight filaments?
Old Feb 16, 2004 | 08:56 PM
jwford's Avatar
jwford
hey yall, my headlight went out tonight. i bought a filament. how do i change it out? i've never done one and mama is fixing to leave and needs it done.???JW
Old Feb 16, 2004 | 09:30 PM
dakota_viking's Avatar
dakota_viking
Open the hood. Look for 2 black pieces of metal sticking up just behind the headlight.
Pull up on these pieces until they stop. The headlight assembly should now come out the front. Remove the wiring harness and the bulb retaining ring. Replace the bulb and reverse the process to re-install.
10 minute fix.
Good luck!
Tim
Old Feb 16, 2004 | 10:37 PM
jwford's Avatar
jwford
thanks dakota! i pulled up the 2 tabs and nada! no zip--nothing!!
i also removed a coupla screws and still nada! i can see it but i don't know how to get to it!----arrgh! I GOT THE PART.jw
Old Feb 16, 2004 | 11:09 PM
50th ann's Avatar
50th ann
Keep playing with those black tabs. They will release the light. You may have to pull them to the front of the truck while pulling up on them but only slightly forward do not bend them.
Old Feb 16, 2004 | 11:57 PM
PaulC's Avatar
PaulC
Actually you tip them slightly towards the back of the truck as you lift them. That will release the locks that keep them from moving high enough to release the light housings.
Old Feb 17, 2004 | 08:58 AM
50th ann's Avatar
50th ann
I had it backwards
Thanks for the help PaulC
My truck must have been backed in when I did it.
Just kiding.
Old Feb 17, 2004 | 11:10 AM
jwford's Avatar
jwford
thanks again yall! first time i'd changed one of the thangs. always great help here!
MrTisLost
Jul 21, 2013 02:18 PM
elitelawnteam1
1997 - 2003 F150
Feb 12, 2013 09:50 PM
jaycenk
Aug 20, 2012 06:33 PM
Matt Scassero
Oct 31, 2008 07:58 PM
dehcho
Electrical Systems/Wiring
Dec 13, 2007 09:44 AM
