maf conversion
Old Feb 16, 2004 | 04:55 PM
47,52,69,92's Avatar
47,52,69,92
maf conversion
i have a '92 5.8L with an e4od trans i want to convert to mas air where do i get the stuff to do it
Old Feb 16, 2004 | 07:28 PM
Ford_Six's Avatar
Ford_Six
Welcome to FTE!
The best and cheapest route would be to get a donor vehicle, most likely a wrecked 96 F-series.
Old Feb 17, 2004 | 12:41 AM
EPNCSU2006's Avatar
EPNCSU2006
I'd look for a '95 instead. The '96's are EEC-V and are very different than the EEC-IV in the '92's. I don't know if you would find a MAF 351 in '95, but a MAF 302 computer would work just fine since the mass of the air is calculated, the fuel would still be calibrated correctly regardless of engine size. Just make sure it is a truck with an E4OD. This is probably the easiest way to get MAF on a truck with the E4OD.
Old Feb 17, 2004 | 08:38 AM
LxMan1's Avatar
LxMan1
I believe that FRPP offers conversion kits. I know that they do for Mustangs.
Old Feb 17, 2004 | 12:52 PM
EPNCSU2006's Avatar
EPNCSU2006
The main thing with FRPP kits is that they don't make one for an E4OD. With any other transmission, that's a very very good way to go.
Old Feb 17, 2004 | 07:07 PM
47,52,69,92
thanks for the info, i will check the junk yards. i am not ready to upgrade my daily driver yet. just doing reaserch for now my garage is already full i've got a '47,'52,'69 in there right now the '47 and '69 are my dads, the '52 is mine.
Old Feb 19, 2004 | 07:00 AM
duff man's Avatar
duff man
there are a few compaines that make the kits they will be the best route to go. they will have everything needed and most important instructions. interactive systems makes them for the fseries if there still in busniess. the mass air meter you use must be calibrated for your current injector size. probally 19lb hr but check if you get a donor! its really simple all you need is the maf meter,ecm and make a few changes to the pin connector. oh and the 4 wire harnese for the meter. but you will need some instructions maybe you can find a set on ebay.
Old Feb 19, 2004 | 01:13 PM
EPNCSU2006's Avatar
EPNCSU2006
It's not quite that simple for a truck with E4OD. Well, if you buy a kit it is, but the kits for the E4OD are nearly 1000 bucks, and on top of that you have to buy a computer. You also have to run two computers, one to control the transmission and one to control the engine, which would be difficult without a kit and a new wiring harness. A donor truck would be by far the cheapest way for a MAF conversion. If it were a different transmission, then by all means, the kit would be the way to go.
Old Feb 19, 2004 | 03:13 PM
47,52,69,92
thanks for the input.
jays92
Sep 22, 2013 12:21 AM
cubb
15
Jul 19, 2006 02:06 PM
fuzbuster
Mar 31, 2003 10:15 PM
Steve0
1978 - 1996 Big Bronco
Mar 31, 2003 06:39 AM
mshumack
Dec 17, 2002 11:03 PM
