leaking fuel line
Old Feb 16, 2004 | 02:17 PM
78f250's Avatar
78f250
leaking fuel line
As is par with my luck lately, I have developed a small gas leak in the fuel line running from my rear tank. I crawled under it yesterday and the line is rusted in a spot and is weaping gas out. I am really not to keen on trying to take this whole line out as I am not sure where it ends. It runs from the back tank along the frame rail but I loose it once it gets next to the saddle tank. Is there any way to fix this without pulling the whole thing out. I have this feeling I will be getting into a $500 fix if I have to start dropping tanks and what not (just from the way things have been going lately...HAHA).
Any problem cutting out the leak and replacing it with rubber fuel injector line? Any other ideas? Thanks guys.
Old Feb 16, 2004 | 03:47 PM
79_250RangerLariat's Avatar
79_250RangerLariat
While some people do not advise putting rubber fuel line in place of metal lines I've never had a problem. Just make sure it's not where metal needs to be (around moving parts, exhaust, etc)
Old Feb 16, 2004 | 04:53 PM
73Custom's Avatar
73Custom
I agree, if you use fuel rated hose and good clamps, it should be fine. The fuel line goes from the rear tank to the tank selector valve - which I think is in front of the aux tank.
Marty
Old Feb 16, 2004 | 05:05 PM
ncl's Avatar
ncl
Putting rubber hose on is fine if it is not a high pressure line like fuel injection requires of if you are using an aftermarket high pressure fuel pump.
Old Feb 17, 2004 | 01:06 AM
toyotaguy's Avatar
toyotaguy
I replaced all of my steetl lines on my truck. it wasent too expensive. i just bought 60" lines of the proper size 3/8 and 1/4 and purchased a tubing bender and cutter and had at it. it took alot of time but it will pay off in the end. because now i have fresh new lines with no rust in them. wont clog up my fuel filter any more. But if your gonna replace the line with a rubber section i would use double hose clamps on each end. there not that expensive and it gives you that little extra holding power where you dont have a barb on the end of the line. make shure the line wont rub on any sharp objects near by or you will have another fuel leak.
Old Feb 17, 2004 | 02:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
If you have a double flaring tool you can put a real nice hose retainer "bead" on the cut ends of that steel line. Then use a section of rubber line to repair the rusted out spot with a couple of clamps.
Old Feb 17, 2004 | 03:02 AM
Matts72's Avatar
Matts72
I had to replace my line a while back, I ran 3/8" fuel rated rubber hose. It works great. Its pretty cheap, but I recall you need at least 12 feet of line.
You need to clamp off the line if you don't have a fuel shutoff, there are flared tubes available at the parts store to connect two pieces, although I recommend using a filter instead.
Old Feb 17, 2004 | 03:10 AM
Torque1st's Avatar
Torque1st
Posting Legend
One of the reasons the OEMs use steel instead of rubber line is that it lasts longer. Unfortunately not forever tho.
Old Feb 17, 2004 | 06:33 AM
78f250's Avatar
78f250
Thanks for all your help everyone.
Old Feb 20, 2004 | 10:39 AM
bob arrington's Avatar
bob arrington
thats a neat idea ,respectfully , bob
Old Feb 21, 2004 | 09:32 AM
73Custom's Avatar
73Custom
I'd feel better with steel line. Too much heat, vibration, rubbing and weather down there to trust rubber hose to safely/reliably carry gas the entire distance. But that's just me.
Marty
BrotherGotaFord
25
Aug 11, 2013 12:22 PM
kaz442
Jul 24, 2012 06:01 PM
Duksrule
Jul 1, 2009 10:03 AM
muddplay
Offroad & 4x4
Jan 1, 2009 07:04 AM
rebel_ford4x4
Jun 9, 2004 09:35 AM
