need help with axle codes
Old Feb 16, 2004 | 01:43 PM
shawn47905's Avatar
shawn47905
Front 3.50 D8TA NE
610047-3
Back FE AS 8AA
3L50 9 394B
the font is bad and needs replaced what are the ratio's and what would be compatable i would prefer to get one with locking hubs.
thanks,
shawn
Old Feb 16, 2004 | 03:02 PM
77redf250's Avatar
77redf250
the gear ratio is 3.50 the rear is limited slip. you can add locking hubs to just about any diff used in a ford
Old Feb 16, 2004 | 10:14 PM
shawn47905's Avatar
shawn47905
is limited slip good? or should i look for a better 1
is the rear ratio 3.50?
thanks
shawn
Old Feb 16, 2004 | 10:31 PM
77redf250's Avatar
77redf250
limited slip(posi) is good it puts torque to the wheel with the most traction. yes the ratio is 3.50 if you doing lots of offroading i'd recommend a larger ratio like 4.10 and some kind of a locker(detroit) and stronger axles especially if you have big tires.
Old Feb 16, 2004 | 11:28 PM
shawn47905's Avatar
shawn47905
thanks fred you have been a tremendous help
shawn
Sparky83
Projects
Nov 29, 2014 10:43 PM
904man
Nov 10, 2014 05:02 PM
Shawn Nobles
Jun 12, 2013 10:05 PM
shawn001
2004 - 2008 F150
Sep 8, 2012 04:19 AM
shawn47905
Electrical Systems/Wiring
Oct 19, 2005 11:08 PM
