1978 - 1996 Big Bronco
Coil Spring Questions
Old Feb 16, 2004 | 01:26 PM
todder53's Avatar
todder53
Does anyone know what the lenght and rateing of stock coil springs on a 1979 Ford Bronco with a 351 is? If not do you know where i could get this info. Thanks
Old Feb 16, 2004 | 10:14 PM
Steve_Uzi's Avatar
Steve_Uzi
Yes, you can goto any GOOD parts store and they can look up all that info in their Spring Book! NAPA will have a spring book! The book lists everything, install height, free height, diameter of the coil wire, spring rate, load rating. You can even use it to get stiffer springs or slightly taller springs.. etc
