fuel gauge not working!!!
Old Feb 15, 2004 | 08:49 PM
boogity24's Avatar
boogity24
My fuel gauge on my 72 doesnt work and hasnt since i got it. i looked on the tank and seen the ground had been snatched out of the screw, i hooked the wire back up but it still isnt working. the needle goes up to e and sits there. the red wire is going into the tank and ground is hooked up, what else is there to check??
Old Feb 15, 2004 | 11:43 PM
X-1's Avatar
X-1
If you are getting power at the tank, then probably sending unit.
Old Feb 16, 2004 | 06:05 AM
stroker393's Avatar
stroker393
Pull the sending unit from the tank and check your float. My 69 gave me fits years ago; the problem was the float which had a pin hole in it so it would fill with fuel and stay on the bottom of the tank always reading empty on the dash gauge - new float cured it.
Old Feb 16, 2004 | 11:44 AM
boogity24's Avatar
boogity24
alrite thanks
Old Feb 16, 2004 | 05:40 PM
1968stepside's Avatar
1968stepside
Yeah, floats are like $3-$4 here in AZ. I had the same problem.
Old Feb 17, 2004 | 03:36 AM
Fryzil's Avatar
Fryzil
Pull the main wire of the unit and ground it, if it (the gauge) goes to full then you have a bad unit or a bad float, if it doesnt do any thing (on the gauge) then you have a bad gauge or wire. Hope that helps.
Chris
