My 1978 Ford F100 has a V6 300 in it. Right now it is misting and spitting and sputtering. I have replaced the spark plugs and wires, fuel filter, fuel pump, and air filter. It is still doing this after I have done all this. It stalls at about every stop sign and red light. Any info will help. Thank You!
check your carb for looseness. if you have the I-6 with the 1 barrel then just grab it and twist. if it wiggles then pull it and tighten all screws. also Blue loctite on the threads will help.
if not get some spray carb cleaner and with engine running spray manifold and any place it can suck air. if idle changes you have a leak
Back when I had a F150 with the 300 six I had the same problem and the bolt that hold the carb were lose thank god for a1/2 in. wrench. I had to snug them every oil change. every 2000 miles I had the truck 10 years great mileage thats all it had.
We found a bolt in the carb that came off. I am having a guy redue the carb. The same guy told be I had a valve out. Anybody have any info on how to fix that.
